waht is Anti-Roll Bar, Sway Bar and Tower Bars ?
Anti roll bar and (anti) sway bars are one in the same. They run underneath the car between either side of the wheels / suspension and come in front and rear varieties. A tower bar runs between the strut towers in the engine bay (on top of the suspension) or in the boot between the suspension strut towers. A tower bar stiffens the chassis.
Originally Posted by tiF adnoH
what is Anti-Roll Bar, Sway Bar and Tower Bars ?
My personal opinion is that strut bars and sway bars work in conjunction with each other. The strut bars alone don't that much. The sway bars will improve your car but times that by 10 with the tower struts. If you want to improve the car's handling, try getting both. Start with the rear sway bar and then work your way to the front. You'll be surprise at how much better your car feels after. But if you're going for the bling bling show look, the front and rear strut should suffice.
Originally Posted by Fray Adjacent
'trailing throttle oversteer'
It's not a hard move to recover from. When it occurs, just slowly increase throttle and fix the oversteer.
