waht is Anti-Roll Bar, Sway Bar and Tower Bars ?
Old May 26, 2006 | 05:28 PM
tiF adnoH's Avatar
what is Anti-Roll Bar, Sway Bar and Tower Bars ?
Old May 26, 2006 | 05:45 PM
Fray Adjacent's Avatar
Senior Member
Imagine turning quickly from left to right repeatedly. The car will 'sway' in the opposite direction, right?
Anti-sway bars help counter that motion, and help to make the car feel more stiff.
Old May 26, 2006 | 07:00 PM
vividjazz's Avatar
Someone that Posts too much
Anti roll bar and (anti) sway bars are one in the same. They run underneath the car between either side of the wheels / suspension and come in front and rear varieties. A tower bar runs between the strut towers in the engine bay (on top of the suspension) or in the boot between the suspension strut towers. A tower bar stiffens the chassis.
Old May 26, 2006 | 07:03 PM
GoFit's Avatar
It's something i want for my Fit
Old May 26, 2006 | 07:10 PM
bitterspeak's Avatar
Like someone mentioned before, the anti-roll bar and sway bar are the same thing. All modern cars are typically fitted with a sway bar. However, the stock sway bar does the bare minimum. What an aftermarket sway bar does is it reduces body roll and "sway" when you turn into a corner. The thicker the sway bar, the more it reduces the chassis flexing. The tower bars, aka, strut bars are mounted on top of your suspension. What this does is it stiffens the chassis so your turn in will improve.
My personal opinion is that strut bars and sway bars work in conjunction with each other. The strut bars alone don't that much. The sway bars will improve your car but times that by 10 with the tower struts. If you want to improve the car's handling, try getting both. Start with the rear sway bar and then work your way to the front. You'll be surprise at how much better your car feels after. But if you're going for the bling bling show look, the front and rear strut should suffice.
Old May 26, 2006 | 08:23 PM
Senior Member
Now... someone ask what 'trailing throttle oversteer' is... hehehe
Old May 26, 2006 | 08:37 PM
aziatiklover's Avatar
Master FitFreaker
lmao yea wat it is??
Old May 26, 2006 | 11:03 PM
"Trailing throttle oversteer" occurs when in midturn, you let off the throttle too quickly and the weight from the rear shifts to the front and the rear tire loses grip and results in an "oversteer."
It's not a hard move to recover from. When it occurs, just slowly increase throttle and fix the oversteer.
jjrf
Dec 6, 2015 12:52 PM
hehn
Aug 25, 2010 02:44 AM
Cadwgawn
Aug 29, 2009 05:55 PM
mikejet
Jan 29, 2009 05:28 PM
pr0jectezek1el
31
Aug 4, 2008 11:45 AM
