Where should I jack my Fit from?
Old May 28, 2006 | 05:02 PM
sharkytm's Avatar
Question Where should I jack my Fit from?
I'm not talking the factory jack, but I like to put jackstands on the factory jack points, and that doesn't leave me many places to stick the jack.
For the front, I've found a control arm mounting bolt that works well, but the rear is an issue. Anyone know where Honda suggests placing a floor jack on the Fit?
Old May 28, 2006 | 07:34 PM
p11wrg's Avatar
I jacked my rear on the rear crossmember. Doesn't seem to have bent and drives straight! so I guess its strong enough!
Al.
Old May 28, 2006 | 08:10 PM
aziatiklover's Avatar
Master FitFreaker
just becarefull with that man my friend jacked my DC5 once from the front and he bent the front frame
Old May 28, 2006 | 09:01 PM
kkim's Avatar
The rear can be jacked from the tow hook area... at least that's where I've lifted all of my previous Hondas/Acuras.
I'd like to know where the front can be lifted w/o causing any suspension damage. Although I know the control arm mounting bolt area should be strong enough, I'm always leery of using suspension points for lifting.
Old May 28, 2006 | 10:46 PM
Master FitFreaker
yea that not bad idea
Old May 30, 2006 | 08:50 AM
sharkytm's Avatar
Any mention of the front? The LCA point is plenty strong, but i'd prefer to place the jack on something flatter, the mount is round, and if the car got pushed, it might come off the jack.
Old Jun 1, 2006 | 01:28 PM
cliu's Avatar
if you look at the service manual, you can see there is a jack point in the front of the car.
Old Jun 2, 2006 | 12:42 AM
kkim's Avatar
Yes, I just got my manual yesterday.
rear jack point....
And the front jacking point highlighted... located between the control arms.
Old Jun 2, 2006 | 03:03 PM
Natloz's Avatar
rear jack point....
Do you have to take off the plastic skirting underneath the front to get to the front jacking point?
Old Jun 2, 2006 | 03:09 PM
kkim's Avatar
No, the front jacking point sits dead center between the control arms under the engine. If you look at the picture, you'll see the exhaust resonator sitting right behind the jack point. If you look really close you'll see my crappy circling of the jack point in purple.
Old Jun 2, 2006 | 03:36 PM
Natloz's Avatar
Thanks, I found it, now that you pointed out the purple circle better. I didn't see it before.
Old Jun 3, 2006 | 11:04 AM
sharkytm's Avatar
rear jack point....
Beautiful... I'm on a Mac, so the downloadable service manual is all but useless to me. Thanks a ton, now I don't have to worry about doing damage when I swap wheels and tires.
Old Jun 3, 2006 | 12:03 PM
Natloz's Avatar
where can I download (to PC) the service manual?
Old Jun 3, 2006 | 12:26 PM
phil_qc's Avatar
3 points
back of front wheel:
front of back wheel:
rear hook:
Phil.
Old Jun 3, 2006 | 12:30 PM
phil_qc's Avatar
Oh, I just re read the post... you already know those points...
I let the pics in case someone want to see the stock jack points...
Phil.
Old Jun 3, 2006 | 04:01 PM
sharkytm's Avatar
Those points are in the manual, but I'm not a fan of putting a floorjack on the front points... it leaves noplace for jackstands.
Old Jun 3, 2006 | 04:20 PM
kkim's Avatar
from my earlier post... this is the front central jacking point according to the service manual.
Old Jun 8, 2006 | 07:51 PM
LiL Wee FIT's Avatar
Im a little confused about the rear...(excuse my stupidity)
So I jack straight from the tow hook? Cause I can't seem to find any flat surface....
And if I jack straight from the tow hoook, won't it be kind of unstable when the car is being jacked up?
Old Jun 8, 2006 | 08:08 PM
kkim's Avatar
Use a hydraulic floor jack at the front and rear jack points to lift. I wouldn't use the scissors jack that comes with the car to lift from those points.
Use of the tow hook in back as the lifting point results in two wheels being raised at the same time. Tow hook is centrally located. The car will balance nicely using the tow hook as the lift point. Once it's up, place jackstands under the side jacking points and let the car back down onto the jackstands. Same with the front.
Old Jun 9, 2006 | 08:23 PM
fm2n's Avatar
You mean like, steal?
