Where should I jack my Fit from?
Old Jun 9, 2006 | 09:53 PM
Okietom's Avatar
Jack one from a dealer that is charging over MSRP.
Old Jun 14, 2006 | 12:46 AM
LiL Wee FIT's Avatar
Thanks for the tip KKim...
I tried it over the weekend.. and my stupid jack doesn't have enough travel to lift the back up. (Didn't bother trying the front)
Which means..... I should lower my car
Old Jun 14, 2006 | 12:52 AM
kkim's Avatar
Yep, lifting from that toe hook in the back requires a jack that can get some lift. I've found when buying a jack to look for one that can lift to about 20" to be of any use to lift from that spot.
Prior to me having a jack that was capable, I did some pretty stupid stuff to get the jack to reach. Suffice to say, spend money on quality tools... you'll be very thankful you did for a long time to come.
Old Sep 29, 2007 | 06:17 PM
Sleep_DEPRIVED's Avatar
Originally Posted by kkim
from my earlier post... this is the front central jacking point according to the service manual.
Does anyone have this picture saved somewhere? I want to know where the front jacking point is. Thanks.
Old Sep 29, 2007 | 06:28 PM
kkim's Avatar
Sorry, picture got deleted off the server. Jacking area circled in a dark purple... look closely, it's there.
Old Sep 29, 2007 | 06:48 PM
Sugarphreak's Avatar
Push My Button
Here is a very informative DVD you can follow, just don't jack my car!!
Old Oct 29, 2007 | 08:07 AM
HEMI-Fit's Avatar
Originally Posted by phil_qc
rear hook:
What's the large pyramid-shaped lump left of the tow hook in this photo? Before reading this thread, I would have guessed that was the jack point...
Old Nov 2, 2007 | 02:49 AM
storm88000's Avatar
Frequent FitFreak Poster
Wow, clean your car!! ^^^^
Old Nov 2, 2007 | 11:05 AM
manxman's Avatar
According to the Fit Service Manual, IT IS!!
Old Apr 2, 2010 | 04:00 AM
gloryhound's Avatar
i just wanted to verify with you guys that the rear jack point is the black metal triangle thing in front of the tow hook?
Old Apr 2, 2010 | 06:49 AM
Perrenoud Fit's Avatar
Thanks Phil, my veiw was red X's
Old Apr 2, 2010 | 10:00 PM
  #32
Strong points to place the jack stands
These were good points to place the stands without bending up the frame
Old Apr 2, 2010 | 10:10 PM
  #33
Talking Be sure to clean up after your done.....
Old Apr 20, 2010 | 12:49 PM
  #34
MNfit's Avatar
^^ where did yoiu put the front jackstands at?
Old Apr 20, 2010 | 01:10 PM
  #35
Wink Jack Stand Points
Under were the lower A arm bolts to the sub frame I will update pic soon
Old Apr 21, 2010 | 07:29 AM
  #36
MNfit's Avatar
cool, thanks for the pics
Old Apr 21, 2010 | 07:46 AM
  #37
crash001's Avatar
From a rich neiborhood they normaly don't lock the doors of their cars lol jk
Old Jun 9, 2012 | 02:59 PM
  #38
fitrocksu's Avatar
Where to center jack Honda Fit?
No, the front jacking point sits dead center between the control arms under the engine. If you look at the picture, you'll see the exhaust resonator sitting right behind the jack point. If you look really close you'll see my crappy circling of the jack point in purple.
Hi I'm new on this Honda Fit blog... Your image on this is missing...would you mind to post your picture showing the jack point at the center of the car? Thank you, I really appreaciate it.
Old Jun 9, 2012 | 03:44 PM
  #39
kkim's Avatar
Old Jun 9, 2012 | 05:09 PM
  #40
Subie's Avatar
Arrow Older thread with pix
Originally Posted by sharkytm
I'm not talking the factory jack, but I like to put jackstands on the factory jack points, and that doesn't leave me many places to stick the jack.
For the front, I've found a control arm mounting bolt that works well, but the rear is an issue. Anyone know where Honda suggests placing a floor jack on the Fit?
Here's an older thread with pictures of jack points front and rear:
https://www.fitfreak.net/forums/2nd-...tml#post907932
