Should I bother trying to clean this engine bay
Old Jun 6, 2010 | 10:16 PM
mxl180's Avatar
07' w/ 75k miles. How do I start?
BEFORE
AFTER
Old Jun 6, 2010 | 11:47 PM
Daemione's Avatar
Doesn't look too bad. :shrug:
I'd start with an overall spray down with simple green. Let it soak, and then hose it off. Do the obvious things beforehand like covering the fuse box & spark plugs.
Old Jun 6, 2010 | 11:50 PM
mxl180's Avatar
Do I cover the alternator?
Old Jun 7, 2010 | 12:48 AM
dewthedew's Avatar
yes with a plastic bad.
Old Jun 7, 2010 | 01:09 AM
LaoSiFu's Avatar
Is that rust being build up?
~Robert
Old Jun 7, 2010 | 01:12 AM
mxl180's Avatar
i'm hoping after a wash and dressing it'll stop the rust.
~Robert
Old Jun 7, 2010 | 01:18 AM
BraytonAK's Avatar
What on earth is all that corrosion from? Rust and aluminum oxidation? Where do you live? I really hope that's not how our cars are going to wear so quickly.
Looks like you need something to neutralize the surface pH.
Old Jun 7, 2010 | 01:19 AM
LaoSiFu's Avatar
What do you mean dressing? Sanding and painting it? FYI water will not remove rust, actually water help causes rust.
~Robert
Old Jun 7, 2010 | 01:36 AM
Texas Coyote's Avatar
Corrosion like that makes me wonder if the car might have been submerged in salt water.... I haven't seen a Fit like that before..... I sure hope the inside of the engine is in better shape.... I would start with some course steel wool followed by medium and fine...The metal lines at the throttle body that are rusting needs to be painted after getting all of the rust and corrosion removed .... It might be better to remove the corroded stuff and take it to a machine shop and have it all bead blaster and clear coat, paint , or have the stuff powder coated..... I am pretty sure you can make it better and maybe even pretty if you put some time and elbow grease into it....
Old Jun 7, 2010 | 01:42 AM
Is it possible that the battery exploded or it was vandalized with acid..... It hurts me to look at it.... I also wonder how the insides of the doors and the underside and suspension looks.
Old Jun 7, 2010 | 10:12 AM
MNfit's Avatar
omg what happened to the engine, battery explode? car in a flood?
Old Jun 7, 2010 | 07:50 PM
mxl180's Avatar
I think it's the salt from the winters
Old Jun 7, 2010 | 07:54 PM
MNfit's Avatar
I dont think its the salt, I live in Minnesota and I dont clean the engine over the winter, mine dint look even half that bad in the spring.
Old Jun 7, 2010 | 09:41 PM
BraytonAK's Avatar
Did you recently purchase this car? Was it from a dealer or a private seller? If it's new to you, I'd look at Carfax, just for peace of mind.
Old Jun 8, 2010 | 08:44 AM
score04w's Avatar
i guess you might as well try. Whats the worst that happens? Cant get any worse than it already is.
Old Jun 8, 2010 | 12:41 PM
honda2112's Avatar
Gad-zooks!!!!!!
Old Jun 8, 2010 | 06:42 PM
Cat's Avatar
Cat
I can't believe that poor neglected Fit engine bay. I have a 2007 and here is what mine looks like - these were just taken a few minutes ago:
Yes, cover up vital parts i.e. battery etc with plastic and you can use an engine clearner and dressing. This one gets cleaned and detailed every time the car is cleaned. I keep after it so that it looks like it is show room . I do show my car but even if I did not I would still include the engine bay everytime the car is cleaned. We want to see some after pictures!
Cat :x
Old Jun 8, 2010 | 08:25 PM
mxl180's Avatar
will clean..and post new pics.
Old Jun 8, 2010 | 08:40 PM
Let the emphasis be on elbow grease rather than chemical agents on the corroded aluminum parts.
Old Jun 8, 2010 | 10:31 PM
mxl180's Avatar
quick clean
