side mirror sub assembly replacement
Old Jun 16, 2010 | 01:55 PM
estlin's Avatar
Hi guys,
So I searched around and I guess if one was to replace the whole side mirror assembly and housing, that you would have to take the door panel off and such, which is a hassle.
I just need to replace the mirror which is cracked...anyone have experience doing this? I'm looking at it and I can't figure how to take just the mirror part off without having to take the whole assembly apart...
Thanks in advance.
Old Jun 16, 2010 | 03:50 PM
jdmgab's Avatar
You don't need to take out the whole door to replace a mirror.
Adjust and tilt the mirror by using the controller inside your car. Let it tilt until you see a big gap. Pry it or pull it, be gentle though as you just want to pry the mirror and not the clip inside.
BTW: Is your mirror replacement just a mirror with an adhesive back or with the clips?
Old Jun 16, 2010 | 04:05 PM
estlin's Avatar
Thanks jdmgab, that's what I figured...I'm just worried about popping it back in and having it snap in place, without breaking the glass under pressure. The part I'm ordering will be just the glass.
Old Jun 23, 2010 | 08:10 AM
Empire's Avatar
Sorry for the delay I hope this helps http://www.hondafitjazz.com/manual/A...021KBAT00.HTML
Old Jun 23, 2010 | 12:07 PM
estlin's Avatar
Awesome thank you, this is perfect. I've seen that site before and been looking around for it.
cruiserandmax
Mar 29, 2015 01:54 PM
Amanda Tabary
Feb 22, 2014 02:48 AM
JDBreeze1
Jun 18, 2012 11:12 PM
timfield
Mar 24, 2011 10:06 PM
mfedor
Oct 31, 2008 10:30 AM
