Keyless Entry remote lost configuration
Old Jun 16, 2010 | 04:20 PM
ciscocampos's Avatar
First of all gr8 forum. I just bought a 2007 Honda Fit Sport (US model) and all of a sudden my keyless entry remote lost it's configuration (stopped working), since the led was loosing intensity I decided to change the battery.
After the battery change it still didn't work, looking at this forum I followed the instructions to configure the controller, it worked but after 2 hours it lost the configuration again.
I have tried to re-configure again but to no avail, your help will be appreciate it so looking forward to your feedback.
BTW, the instructions I followed were:
Keyless Entry Transmitter ProgrammingThe codes of up to three transmitters can be stored into the keyless reciver unit memory. (If a fourth code is stored, the code which was input first will be erassed.
NOTE: It is important to maintain the time imits beween the steps. Make sure the doors and the tailgate are closed.
1. Tuan the ignition switch ON (II).
2. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit.
3. Within 1 to 4 sec, turn the ignition switch OFF.
4. Within 1 to 4 sec, turn the ignition switch ON (II).
5. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit.
6. Within 1 to 4 sec, turn the ignition switch OFF.
7. Within 1 to 4 sec, turn the ignition switch ON (II).
8. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit.
9. Whithin 1 to 4 sec, turn the ignition switch OFF.
10. Within 4sec, turn ignition switch ON (II).
11. Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter animed at the keyless receiver unit.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec, push the transmitter lock or unlock button again.
13. Within 10 sec, aim the transmitters (up to additional ones) whose codes you want to store at the keyless receiver, and press the transmitter lock or unlock buttons.
Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation with the transmitters.
And I don't hear the door actuators any more, only when I do it manually.
Thank you very much!
Cisco
Zute
Jun 3, 2019 10:21 PM
jessec
Apr 29, 2016 11:35 PM
madxpinklady
Nov 17, 2013 08:48 AM
Ja55
May 25, 2007 09:45 AM
U.S.Bjorn
Mar 6, 2006 08:53 AM
