Vtec controller?
Old Jun 2, 2006 | 12:49 AM
007Fit's Avatar
Vtec controller?
Has anyone installed a vtec controller in there fit yet?
Old Jun 2, 2006 | 01:07 AM
07TaffetaFit's Avatar
I will go ahead and stop this before you get attacked. The Honda Fit's version of VTEC is nothing like the traditional VTEC you are thinking of which uses different cam lobes. All the L15As "VTEC" does is during normal driving, only 2 of the 4 valves are being used, once a certain RPM is reach all 4 valves kick in. I am assuming this is used to create better gas mileage.
Old Jun 2, 2006 | 01:25 AM
aziatiklover's Avatar
Master FitFreaker
big waste of money and it will mess your car up as well. Just wait for the hondata version
Old Jun 2, 2006 | 01:39 AM
007Fit's Avatar
i honestly did not know the difference and logic behind the fit's vtec system./.
thx for the info though.
What are yoru thoughts on an Aem EMS for the fit if it ever come;s out..
Old Jun 2, 2006 | 11:25 AM
dougiepants's Avatar
Avid FitFreak Poster
wait for Hondata version for sure
Old Jun 2, 2006 | 11:31 AM
Master FitFreaker
yea thats wat i'm waiting on and the comptech SC or mugen
Old Jun 2, 2006 | 03:31 PM
Originally Posted by claymore
Before you get flamed direct from the Honda repair manual:
"VTEC System L15A1 engine
The VTEC system changes the cam profile to correspond to the engine speed by the VTEC solenoid valve. It maximizes torque at low engine speeds and output at high engine speed.
The low lift cam is used at low engine speeds, and the high lift cam is used at high engine speeds."
How can that be right? I thought the L15 used a new system that used 2 valves until a certain RPM and then kicked in all 4 valves above that RPM? What you said sounded like the conventional VTEC.
Old Jun 2, 2006 | 03:35 PM
Jonniedee's Avatar
Question
According to Wong over at Temple of VTEC Asia - it's not a 2 / 4 valve VTEC but a 3/4 valve with an additional intake valve only opening ...
http://asia.vtec.net/Series/FitJazz/lseries/index.html
"The VTEC mechanism on the L15A VTEC is that of a 1-valve/2-valve system for the intake side only. The exhaust side always functions as a 2-valve system. So the L15A VTEC is a 12valve/16valve system."
Old Jun 2, 2006 | 06:22 PM
that makes sense
Old Jun 5, 2006 | 02:09 PM
Golof's Avatar
Actually the Vtec controller will work on the fit and it will work just like it does on any of the other Vtec cars. Check page 35 on the New AFC NEO for the wiring diagram for the gd3.
Old Jun 22, 2006 | 09:31 PM
fitwannab's Avatar
Has anyone acutally hooked one up to try it? Insted of arguing about it lets hear if it works or not.
Old Jun 23, 2006 | 05:34 AM
03DSM-RSX's Avatar
Frequent FitFreak Poster
vtec controllers are NOT a good idea. i've tried them on several cars including my own. after dyno tuning, it looks good on the dyno with ~10hp increase, but the car runs very odd. cylinders misfire due to weather changes, which those AFC's dont have-temperature compensation. also, they cant tune cam angles and ignition advance.
it will work as in the displaying and hooking up wires, but as for the tuning aspect, its just plain SHIT. i got rid of it on ebay, got hondata kpro. best shit ever.
i have close ties with Hondata. they've already checked out the Fit's ecu and stock fuel maps. they've determined that it was already WELL TUNED from the factory and any attempt of them trying to make it better would not be worth the money.
the only time u'll need to worry about EMS's is when u boost. so dont bother with it if u're n/a.
Old Jun 25, 2006 | 03:10 PM
fitwannab's Avatar
thank you very much that was the exact thing myself and everyone else needed to hear.
Strumbone
Jan 8, 2015 06:33 AM
Austinite
Mar 25, 2013 01:53 AM
kvnzenbe
Jun 7, 2010 01:39 PM
Fitcious
Jul 26, 2009 01:56 PM
tonyd3773
Feb 9, 2008 12:03 PM
