advice needed on offset!
Old Jul 23, 2010 | 10:54 PM
ohanahuichubbz's Avatar
Im in the market of picking up cheap rims... i am looking at rota d2's (work/ssr reps) 17x7.5 up front and 17x8.5 in the rear. im also checking out g-force's 17x7.5 up front and 17x8 in the rear or slip streams 17x7.5 front and 17x8 rear.
forgot to mention...im dropped on buddyclub n+...i am willing to roll/pull.
im assuming if i run 8.5 rear ill be on 205 rubbers and 7.5 with 195 in front.
any info will be appreciated!
QUESTION:
what offset would you guys recommend???
d2's
17x7.5 +48,45,35 (front)
17x8.5 +48,45,25,20 (rear)
g-force's
17x7.5 +35,45,48 (front)
17x8 +48 (rear)
slipstreams
17x7.5 +48,45,40 (front)
17x8 +48,40 (rear)
Old Jul 25, 2010 | 02:09 PM
gimme's Avatar
Master FitFreaker
it really depends on what look you are going for. I can gauge it by the 195 on a 7.5 wide wheel that you might be looking for the oh so famous "hella flush", but let readers know what your end result look is desired so they can help accordingly.
Old Jul 25, 2010 | 09:04 PM
got it. thanks for the info. i finally made up my mind. im going with the d2's in gold. im thinking about running +45 on all corners and then adding spacers in the rear to make it flush. OR should i go with +25 in the rear? someone help me!!! and yes, im going for hellaflush look.
lowkeymods
Jul 30, 2013 01:47 AM
djfof
Mar 24, 2011 09:32 PM
ohanahuichubbz
Jul 25, 2010 09:24 PM
ohanahuichubbz
Jul 23, 2010 10:53 PM
ohanahuichubbz
Jul 23, 2010 08:48 PM
