install 60w H4 bulb over factory 55w H4 bulb? bad ?
Old Jul 30, 2010 | 12:10 AM
mxl180's Avatar
I ordered
Philips Crystal Vision Ultra bulbs
Then I realize they are 67Watt (high beam) / 60Watt (low beam).
Since factory wires can take 65Watt high beam, if I just use low beam (60Watt) I should be fine?
Old Jul 30, 2010 | 04:01 AM
xonexlifex's Avatar
O hell ya ull b fine. Theres a lot people running those bulbs. It doesnt matter too much. My old silverstar ultras have that same wattage and it didnt matter wat so ever. Ull b very happy to know now that ull b fine running these bulbs
Old Jul 30, 2010 | 06:30 PM
Fit4Trav's Avatar
^^Not quite!
These tend to run at a hotter temperature which can cause the harness to melt.
Old Aug 1, 2010 | 07:44 PM
ramjet's Avatar
I thought someone...ill have to remember the poster but he had the 90watter motorcyle bulb and didnt have any issues. anyone remember?
Old Aug 1, 2010 | 08:04 PM
J_L's Avatar
J_L
Sid 6.7 installed 90w bulbs.
Old Aug 1, 2010 | 08:07 PM
mxl180's Avatar
cool.. thanks for the info
Old Aug 1, 2010 | 09:37 PM
Type 100's Avatar
Originally Posted by Fit4Trav
^^Not quite!
+1
Over here, the usual procedure for higher-wattage bulbs involves adding relays and swapping out the headlight sockets for ceramic ones.
Old Aug 3, 2010 | 05:35 PM
jadr09fit's Avatar
A few watts isn't going to matter. If you went from 55 watts to 80 watts, you'd need a proper relay harness with thicker wiring and relays to handle the higher current. Going from 55 watts to 60 is well within the tolerances of the wiring.
Of course, with the factory wiring being spaghetti, adding a proper harness would let those bulbs be as bright as they can be. And, there's about zero chance of toasting the factory wiring. Unless you're a complete dunce at plugging the harness in.
My Buick's been running a relay harness for 1.5 years with no ill effects. The bulbs are noticeably brighter with the harness than without.
mav238
Jan 14, 2015 02:59 PM
Morair
May 9, 2012 08:26 AM
sdiesel619
Oct 18, 2010 01:21 PM
urbnzeus
Jun 1, 2009 10:26 PM
Jimmy101
18
Jan 22, 2008 04:20 PM
