Fit Computer
Old Jun 3, 2006 | 04:59 PM
shneor's Avatar
Fit Computer
Does anyone know how to access the Fit's onboard computer? Or what equipment is needed? I'd like to check the computer and "black box".
Thx,
Shneor
Old Jun 4, 2006 | 03:27 AM
vividjazz's Avatar
Someone that Posts too much
ODBII port under the steering wheel.
Some gear here
http://www.digimoto.com/
And Greddy Intelligent Infometer
And can get Apexi VAFC
And the Pivot controller
Old Jun 4, 2006 | 04:42 PM
shneor's Avatar
Thx!
I'll check it out!
Old Jun 4, 2006 | 08:57 PM
aziatiklover's Avatar
Master FitFreaker
I say just wait for hondata best choice out there for any honda
Old Sep 17, 2007 | 10:45 PM
Fit Ippo's Avatar
a bud dy just got his TSX Hondata today and it was night and day he didnt make that much on peak power but he gain a grip on mid range but after looking over the afr charts it didnt look like it was perfect so even with a hondata tune i would also get a vafc to fine tune the car
Old Sep 17, 2007 | 11:52 PM
743power's Avatar
the whole point of hondata is fine tuning, its not just an eprom you drop in and call it a day. VAFC is just a map signal manipulator with a limited range of adjustment.
Old Sep 18, 2007 | 12:50 AM
Fit Ippo's Avatar
hondata for the tsx and for alot of cars that are current are pretty much a flash, a base flash pretty much they say a car gots and CAI, exhaust, test pipe, and a header we got a basic tune for it. if your car is like a rsx or earlier obd2 cars (civic, integra etc) then there are other option available to "fine to the car" but if the only thing you have is a basic flash you can use a piggyback computer (vafc) to fine tune your car further.
yes a vafc is just a unit that munipulates the fuel maps on your car at certain rpm ranges (i think 16 differant rpm point) it really doesnt change that fuel maps of your car but just trick your car into adding more fuel or taking away fuel.
but yes a flash is a great tool and it does change alot of points in a car (ignition, fuel, vtec engagement) but no 2 cars are ever alike no part are ever the same so there could never be one flash that workd on all cars just one that yeilds a good average.
Old Sep 18, 2007 | 09:47 AM
txmatt's Avatar
Thx,
Shneor
Are you just wanting to check/clear OBD codes, read sensor values, etc or actually changing things like timing advance and such?
Old May 13, 2008 | 09:12 AM
Fit_61's Avatar
ScanGuage II for the Fit
For ODBII data, to scan and read codes and track
Fuel Economy
Fuel Rate "Gallons Per Hour"
Battery Voltage
Coolant Temperature
Intake Air Temperature
Engine Speed (RPM)
Vehicle speed (MPH)
Manifold Pressure (not available on some vehicles) [DOES work on the Fit]
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
Check out ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool
IS300na-t
Sep 2, 2009 10:19 PM
FITTECH
Mar 7, 2009 11:22 AM
YeeFit
18
Sep 24, 2008 12:49 PM
YazzFlute
Sep 15, 2007 12:56 AM
Endless
May 22, 2007 07:44 AM
