Problem with my projectors
Old Aug 26, 2010 | 12:50 AM
tcasberg1's Avatar
I'm looking for a bit of help troubleshooting. I just purchased a set of morimoto projectors for my 08. I set the system up before I reassembled the entire front end and found that when I turn the lights on they only light in the high beam position and the solenoid only switches to the low beam position if the lights are turned off. The light switch on the dash shows switching from the high to low position. Anyone lend a hand?
Old Aug 28, 2010 | 02:45 AM
danger69's Avatar
Try swapping the lo and hi beam wires.
Old Sep 2, 2010 | 07:12 PM
tcasberg1's Avatar
Still no go. Received a new harness and still same outcome
Old Sep 6, 2010 | 05:50 PM
tcasberg1's Avatar
Ground wires (left and right) are lighting up a test light. And when touched to chassis, spark. No power supplied to harness except thru power line on harness and connector from cars original harness. Not good, any insight?
Old Sep 7, 2010 | 07:22 AM
90crxfreak's Avatar
switch the solenoid wires they are backwards
Old Sep 7, 2010 | 08:20 AM
Goobers's Avatar
Hum... you need to take a picture of what you are talking about.
Is your harness running power directly from the battery through a relay?!?
If not, I'm betting there's the problem, the Fit doesn't power the H4 like most other cars... supposedly, there's one power in and TWO negative/ground out instead of two in and one out.
The solenoids could therefore be "correct" just wrong for the Fit, you'd have to reverse the wires like others have mentioned.
StewMJC
Oct 4, 2018 12:41 PM
Thismightnotfit
Jun 19, 2011 10:53 AM
WhEreZmYFiT
Jan 18, 2011 08:12 AM
Arisenfury
Mar 19, 2010 09:46 PM
ElanS2
Aug 12, 2009 08:11 AM
