DIY: Fog Light Lens Fix/Replacement
Old Sep 7, 2010 | 09:12 PM
heymikesays's Avatar
One of my fog lights broke this morning. After reading the forums (thanks to all who contributed), I decided to try fixing the fog light myself along with some step-by-step pictures. Here is what I used (the shot glosses are optional, depends on how bad of a time you have doing this) All in all, I spent $20 excluding the tools and items I already had. IMO, much more better than spending 200-500$ on replacements. Let me know if you have any q's:
4 Tiny Spring Clamps (home depot)
1 Small sheet of lexan plexi-glass (home depot carries them)
1 Silicone Sealant and Caulk Gun (home depot)
1 Dremel tool with bits (already had this for years)
Some needle nose pliers, flathead (to pry the glass out)
First, here's a pic of the broken mess I started with:
Old Sep 7, 2010 | 09:13 PM
Step 2
Make sure you take out the light bulb first for obvious reasons. Then carefully take out the broken pieces using the needle nose pliers and/or flathead. (Finished result to left, pieces to the right). I would recommend using gloves and eye protection for this because the glass crumbled into tiny pieces and it was not pretty.
Old Sep 7, 2010 | 09:18 PM
Step 3
Use the fog light to trace the desired lens shape on the lexan glass (Do NOT take off the film until you are ready to install the plexi glass, otherwise you will more than likely scratch/scuff it up prior to install):
Once you dremel the desired shape out, sand/dremel-sand the edges to round them out. I used a red sharpie to mark the areas that needed to be sanded in order for it to fit better in the housing.
Old Sep 7, 2010 | 09:23 PM
Step 4
Once you have the right shape out, clean up all the mess/dirt and peel off the film.
Apply the sealant around the housing border and lay the lens on top. Use the small spring clamps to secure it to the fog light (those clamps only cost $0.38 at home depot).
Old Sep 7, 2010 | 09:30 PM
Step 5
Let it dry for a good 30min to an hour (try to wait longer to ensure a good dry and not be antsy like me) I reapplied my fog light housing trim and here is what the end product looked like (I can see the excess sealant I applied but I guess it's better than not having enough sealant and leaking):
Back in it's home.
Old Sep 8, 2010 | 01:36 AM
SoUnFit's Avatar
great write up, good job!
Old Sep 10, 2010 | 11:53 PM
Blue-Civic-Hybrid's Avatar
Thanks for this write up, I have to fix my fog light lense this weekend!
Old Sep 12, 2010 | 01:59 PM
Exclamation Foglight repair and new armor!
Thanks to Hey Mike for the sweet step by step, here is how mine turned out today.
And I also fabbed up some armor for my other glass foglight and see how long it lasts.
more pics to come today after I get my repaired light to dry...
Old Sep 12, 2010 | 02:28 PM
Talking Foglight Armor and stained repaired lens..
As promised, here are some pics of what I just completed in my garage for the foglight repair.
Painted to match my glass foglight...
Debating to install my armor screen..
Installed back on Fit...
Old Nov 19, 2010 | 06:42 PM
lhh305's Avatar
So can you please show me how to take the frog light bulbs out?
Old Jan 12, 2011 | 06:18 PM
zymo's Avatar
this would be a good addition to the DIY.
sort of related - is there a diy for the mesh grill for fit sports?
Old Feb 7, 2011 | 01:35 PM
jdubatl's Avatar
Sweet! Sure beats paying for a new foglight! Thanks!
Old Feb 8, 2011 | 11:18 PM
alexandrebr's Avatar
Nice DIY.
Here in Brazil, on Civic Club, some guys have been doing that job using polycarbonate and Loctite sealant for high temperatures.
I do really think it's much better than replacing the foglight, especially for us here; unfortunately, dealers in Brazil sell only complete kits... so the buyer has to keep harness and all the stuff for a "small price" of U$ 800.00.
Old Feb 24, 2011 | 06:58 PM
kbri's Avatar
Lexan is a brand name for Polycarbonate, so this is the exact same repair, FWIW.
Old Aug 20, 2011 | 01:38 PM
polemos's Avatar
I've 2005 Elite Jazz with broken fog light lenses.
How can i remove the housing from the bumper?
Old Sep 20, 2011 | 11:56 AM
Jazzfitman's Avatar
Glasses can to be drilled, it is enough to heat up in an oven to 50 degrees on Celsius and accurately to pull out from hermetic
Also glasses from Mazda car here a code will approach MZX0303-080-Z
It is necessary a little подтачить a headlight and here is how it looks in gathering
Old Mar 16, 2012 | 12:07 PM
Leo46's Avatar
Fog light repair
Would like more information as to how to access the fog lights so that this DIY repair can be made. Look like a great way to save some money.
Old Mar 26, 2012 | 07:42 PM
JoeLrgr's Avatar
Look inside the mouth of your FiT right next to the Foglight shroud, there will be one Phillips Screw to remove and the whole assembly will slide out.
I just did this today just waiting for glue to dry. VERY happy so far. One of my fog lenses was busted and I decided id do both so they looked alike and found the other was cracked anyways.
Old Mar 26, 2012 | 08:08 PM
Triskelion's Avatar
Replacement Fog Lights
The DIY plastic lense replecement info. was good for people on a low budget, but the Lexan lenses will deform if you use any high-power bulbs, from sources like PIAA (because of heat produced by the bulb). Also, polycarbonate plastic scratches easily.
If your lense breaks from a rock impact, you can find enitre replacement light assemblies on eBay that cost less than OEM lights from a dealer. I recently bought a replacement light assembly, with a glass lense and a fit exactly the same as OEM for less than OEM price from eBay. The light BRAND was TYC, and it was an exact copy of the OEM light that I removed from the car. Seemed a shame to pitch the old OEM light assembly into the trash.
I also installed impact resistant yellow films from "Headlight Armor", and the film fit was exact and easy to install. The Headlight Armor product was thick and of good quality, and the shipping was quick.
I would be happy to post the eBay vendor's name, but I bought the replacement light assembly about 1-1/2 months ago and threw away the packing slip. Just got around to installing it today- a carbon copy of OEM lights.
Old Jun 4, 2012 | 12:32 PM
D50boy's Avatar
Has anyone had issues with the Lexan melting? I have a broken fog and I'd like to get going on a repair for it. I don't want to have to re-do it after melting though.
