Breather tube Vs. Breather Filter?
Old Sep 13, 2010 | 08:19 PM
GoFits's Avatar
I have the T1R intake and right not I've got a tube that connects to the factory breather tube for the crankcase.(I suppose)
I've seen people opting out of connecting that to their intake and just installing a small conical/cylindrical filter to it.
I think I might try that but am not sure about how to plug the hole left from the tube?
Am I rambling here?
What do you think Forum?
Old Sep 16, 2010 | 05:53 PM
Tofuman's Avatar
Firstly, it's bad for the environment. Secondly, check your local emissions regulations - It's illegal in most states to modify it to vent blow-by gases into the atmosphere.
Old Sep 18, 2010 | 11:31 AM
GoFits's Avatar
Wait..what?
Is air/oil/stuff going in or out?
If it's out then I guess I'll just modify mine to fit better.
(It's the current fitment that bothers me)
Old Sep 18, 2010 | 11:45 AM
polaski's Avatar
That is the inlet tube for crankcase ventilation, meaning going into the engine. The PCV valve restricts its exposure to vacuum in the intake manifold but it is always passing some amount of air in that direction.
Some vapor can be pushed out at full throttle operation due to pressure leakage past the rings but IRL it's minimal.
If you can hook up a tube to the intake, that's the better route as well as the most legal one; if you can't, and use a breather filter, you're only going to leak about 1/1000 the vapor of the farmer's 8N down the street.
Fuelish
Oct 7, 2017 03:11 AM
hydesg
Apr 20, 2017 07:28 AM
Myxalplyx
Apr 11, 2015 09:56 PM
boojum
Mar 15, 2009 02:24 AM
coldstorage5
Sep 1, 2006 01:33 AM
