Will this work? 18 X 7.5 4-100 45offset
Old Oct 6, 2010 | 07:12 PM
fargasj's Avatar
Question Will this work? 18 X 7.5 4-100 45offset
Will this work? 18 X 7.5 4-100 45offset on a 2010 Sport?
Old Oct 6, 2010 | 07:13 PM
fargasj's Avatar
With 215 x 35 x 18 tires.
Old Oct 6, 2010 | 07:15 PM
DreaMv's Avatar
stock height it should work... why soo big though? i would stay 16 or 17 for the GE
Old Oct 6, 2010 | 07:19 PM
fargasj's Avatar
Plan on droppin it, how far should (or could I) go?
Old Oct 6, 2010 | 07:22 PM
DreaMv's Avatar
if you drop it, youre forsure going to need to do some fender modifications (cuting, rolling, pulling) and some negative camber . im not an expert soo i couldnt tell you exactly how low you would be able to go..
Old Oct 6, 2010 | 07:25 PM
fargasj's Avatar
I saw this on this site:
Originally Posted by hndaluvr
Naw Baby... themz 18s! They're 18x7.5 et45 with 215/35/18s
the drop is with Tanabe DF210. the rears fit perfect and the fronts will give only a slight "squeek rub" on things as big as speed bumps and large, quick approahing dip/rises in the road surface. looks great, handles great, but i do suffer the slightly harsher ride quality of 35 series tires.
Old Oct 6, 2010 | 07:39 PM
DreaMv's Avatar
then i guess you should be safe on a modest drop if you plan on dumping it, you'll do fender mods
electron_si
Aug 22, 2011 08:43 PM
danielg
Dec 15, 2010 02:46 PM
mk donz
May 27, 2010 02:26 AM
AP_ONE
Apr 16, 2010 02:42 PM
Fit2bFit
Mar 3, 2009 02:08 PM
