Jazz lift...
Old Oct 14, 2010 | 11:36 AM
jazzy06's Avatar
Jazz lift...
I know most of you talk about lowering your ride, but i got my problem about lowrider...
I just bought Jazz (Fit) '06, it look too low and the road around my house is bumpy, i want to lift it a bit, like 1.5"... any idea?
Thank's for the reply
Old Oct 15, 2010 | 05:40 AM
jazzy06's Avatar
so all the member is lowrider lover? no one here like short of rally style?
Old Oct 15, 2010 | 06:19 PM
gynosis's Avatar
post pics, but if you want some 4x4 action just put stock springs in.
Old Oct 15, 2010 | 06:40 PM
Hootie's Avatar
The only ways (that I know of) to safely raise a Jazz's ride hieght (if on stock springs) is to either get taller tires or a set of coil overs that allow the Jazz to be raised. I know Killer Bee makes some for the US spec Fit that raises it slightly higher than factory, but I do not know if the coil overs will work with the other spec models.
More than likely, you will need both taller tires and coil overs just to get desired increase in ride hieght.
woozewing
Oct 4, 2015 09:36 PM
fillit
Sep 20, 2010 08:35 PM
Illusive
Jan 31, 2007 01:41 AM
michaelj
18
Mar 3, 2006 07:29 AM
kimo
Dec 28, 2005 07:10 PM
