Loud Squealing Noise
Old Jul 27, 2010 | 04:10 AM
ToyotaFIT's Avatar
Hey everyone! I just purchased and installed my SKunk2 Pro-C coilovers (group buy FTW!) and used this website to help me install it: Honda Fit Skunk2 Pro-C Suspenion Installation - JHPUSA
I ended up with a very mild drop (0.5" in front and 0.75" in the rear) and I'm running on damper setting #7. The car rides nice... except for one problem...
there's a loud horrible squealing/squaking noise coming from the passenger side front suspension. It sounds as if the tires are dragging (aka the sound that a tire makes when turned on the smooth parking garage pavement). It happens sporadically only when I go over 25mph and it happens even more so when I hit bumps in the road or make turns. I triple checked the nuts/bolts on everything i installed and followed the instructions to the letter.
Some suggestions I have heard is the end-link? But my end-link it tightened while the rim was on the floor. Some say damper setting, but I tried stiff to soft. Could it be my alignment? It feels super off right now... Any further clues? Please help! thanks!
Old Jul 27, 2010 | 12:08 PM
Btrthnezr3's Avatar
Ok here's something to check...make sure that you put the little rubber "hat" onto the shock/spring assembly before you put it back into place. That may cause the noise.
I almost did this on my spring install and then found the hat and went oh shit.
Old Jul 27, 2010 | 01:03 PM
ToyotaFIT's Avatar
Good suggestion, though I just double checked and yes the rubber hat pieces are there.
Any other ideas? I'm really feelin like its the alignment the more that I drive it, the wheels feel to be going in different angles...
Old Jul 27, 2010 | 01:05 PM
Texas Coyote's Avatar
Yes you did for sure.... Damn, I know one person that was very red faced about that...
Old Jul 27, 2010 | 02:35 PM
GD3_Wagoon's Avatar
it's probably your alignment. when i went from pro-c's back to stock springs/shocks the toe was so bad i could hardly drive it on the street -- lots of tire squealing when i'd get over 10mph. when i got it fixed the read out was -4 degrees left front and +0.5 degrees right front or something like that
Old Jul 30, 2010 | 12:12 AM
ToyotaFIT's Avatar
great comments. the bad toe/alignment was right on the mark. the solution was an alignment, costed me $100+
i think im done with my car for now...
Old Oct 23, 2010 | 04:19 AM
tanukifit's Avatar
Eh ToyotaFit, how's the Skunk's working out?
El Chupacabura
Feb 10, 2011 10:08 AM
aZnCdn
Mar 27, 2010 07:53 PM
kingofpicklez
Nov 22, 2009 03:31 PM
GD3_Wagoon
37
Feb 25, 2009 12:34 PM
saiko
30
Apr 12, 2008 11:42 AM
