Sponsored by:
Sponsored by: CARiD
Fit the Spare
Old Jun 9, 2006 | 03:14 PM
willmax11's Avatar
Fit the Spare
I did some measuring of the spare wheel and the reg. 14" Fit wheel. I also
measured a 13" wheel from my 82 Celebrity.
21"---small spare
24.5"-13" (P185/80R13 BF Goodrich)
22"---Fit 14"
When I put the 13" wheel in the spare well it fit but I had to yank it out, tight fit. So if you want to know if a wheel will fit in the well, anything
around 24.5" diameter will go in but not sure if the cover will close.
I took some pictures to compare the Celeb wheel to the reg. 14" Fit.
Old Jun 9, 2006 | 03:34 PM
Packy's Avatar
Frequent FitFreak Poster
So the Fit 14" could fit in the spare tire area? How wide is the Celebrity wheel compared to the Fit 14"?
[edit] PS thanks for the pics
Old Jun 9, 2006 | 05:21 PM
dougiepants's Avatar
Avid FitFreak Poster
nice comparison...
Old Jun 12, 2006 | 01:39 AM
stugotts's Avatar
hey will, u have to much time on your hands
Old Jun 12, 2006 | 06:33 AM
sillypuddy's Avatar
Someone that Posts too much
with the larger wheels, you weren't able to put the trunk floor flat?
-joe
Old Jun 12, 2006 | 08:47 AM
willmax11's Avatar
Being retired does have it's bene-fits. LOL
I always test things out, at least I still have $1,000 in my bank account
b4 I think about new wheels.
No, I didn't bother checking the cover as the 13" would not be going in there and I wasn't going to remove a 14" wheel to check. All that would be needed would be rubber spacers like the foam ones at the front of the cover to raise the gap.
Someone had asked earlier if a reg. tire would fit in the spare wheel well.
Old Jun 12, 2006 | 09:19 AM
kps's Avatar
kps
Honda Fit Forums Moderator
Any idea whether a 13" rim will fit over the brakes? 155/80R13 would make ideal snow tires.
Old Jun 12, 2006 | 09:49 PM
Spule 4's Avatar
All:
While I had the impact wrench out rotating tires on the Camry, I took a wheel off of the Fit. No, you cannot put a full size tire in the well, it will fit in the hole, but the cover will not go flat.
Bummer, as I wanted to get another steel wheel and "play" with a Nokian i3 tire as a spare, to see if they were worth it for when the Dunlops wear out.
Old Jun 12, 2006 | 11:09 PM
willmax11's Avatar
[quote=Spule 4]All:
It will sit flat if you just add shims to the btm. of the cover or add them to the sides of the trunk.
It's so easy it's ridiculous.
Old Jun 12, 2006 | 11:35 PM
Spule 4's Avatar
[quote=willmax11]
Originally Posted by Spule 4
All:
OK? Gotta ask, how do you get around the two side bits that are not part of the lid, and also, when you fold the seats flat, then the same deal....
My seats are flat quite often, being a long time wagon owner....going back to a highly modified '66 Volvo Amazon .
Old Mar 8, 2008 | 09:44 PM
FitRigger's Avatar
Has anyone successfully added a 15" full sized tire with original rim into their spare compartment; while resolving the issue of the trunk lid being raised. Also the issue of the lid fabric being connected to the rear seats? I think you might have to cut the fabric so you can raise the lid properly.
I guess the solution for the gap that you make once you cut the fabric would the the luggage mat, but I'm not sure how well it would fit altogether.
I'm planning to do this myself and wondering if anyone has any suggestion on foam type. I want to be able to keep the lid sturdy enough so it stays flat and doesn't buckle when you put things on the side. I don't mind it being raised.
Here's a link to the luggage mat.
http://www.japanparts.com/db/partslist.php
Thanks for any info.
alanchan
Sep 6, 2012 08:24 PM
FitStir
May 16, 2012 09:21 AM
dutchdog
Oct 11, 2011 03:04 AM
califas05
Jul 2, 2011 12:21 PM
F0NIX
Apr 5, 2007 03:50 PM
