After the rain...no more horn
Old Oct 20, 2010 | 01:41 PM
CrystalFiveMT's Avatar
2 years ago I installed Fiamm El Grande horns myself on my Fit. The other day, driving thru rare rain storm on the freeway, my horn now does not work.
Anyone have any clues?
Old Oct 20, 2010 | 01:46 PM
TunaDaMan's Avatar
check the simple stuff first, check to see whether your horn is still getting power, the wire may have come loose or check its grounding.
Old Oct 20, 2010 | 02:08 PM
Committobefit08's Avatar
Water probably got in it.... make sure it doesn't have any water it. If it does drain it and let it dry completely. Might take a while. Mine got water in it and it was really quiet. I thought it was dead or dying. I drained it out and let it dry and it is back to normal. After that I changed the angle it was mounted so no water would collect in it.
Also check the fuses...make sure it didn't pop a fuse.
Old Oct 20, 2010 | 06:50 PM
FITrunner's Avatar
I am guessing water. Same thing happened to my Integra. Only difference is the Integra tried to turn into a submarine as I missed a very deep spot of water. Dried out after a few days and all was good.
Old Oct 20, 2010 | 11:55 PM
Thanks for the tips guys.
Well, my horn resurrected itself today. Even though I checked most of the connections, it still didn't work. The 2 horns were angled downward as I installed them, so I don't think water got in them.
But, later I tried pressing the horn continuously and soon it made a little BAP! After pressing it often it came back to full blast. So though it looks as though some component needed time to dry out, I dunno from where.
Anyway, it's working now.
Old Oct 21, 2010 | 12:38 AM
TunaDaMan's Avatar
Well cheers to that.
I might consider the possibility that when it was wet, the water shorted the connection between the horns power (the wire that goes to the horn(s)) and the ground (chassis which the horn is bolted to). Thus bypassing the horn when it was wet and as it was drying out the power started traveling through the horn again until it was fully dry and you have your full powered horniness back
Old Oct 21, 2010 | 11:15 AM
Iamnotkento's Avatar
where did you get the horn? i hate how the stock horn sounds.
Old Oct 21, 2010 | 11:53 AM
CollegeHills Honda
or any honda supplier.. part # (Part #38100-STK-A02)
https://www.fitfreak.net/forums/2nd-...n-upgrade.html
Old Oct 21, 2010 | 12:26 PM
gelan's Avatar
dbcmaster
May 16, 2017 07:34 AM
wampy
Dec 16, 2011 01:27 PM
AndrewLOL
Jan 29, 2011 10:37 AM
BenjaminFit
Dec 7, 2010 07:38 PM
Vampgrrl
May 26, 2007 01:52 AM
