back up fuse keeps blowing
Old Oct 24, 2010 | 10:52 PM
mixmastermel's Avatar
I replaced my factory stereo with an aftermarket one. I installed with the new center panel and everything. Started my 2008 Fit Sport up and radio worked just fine. Then a bit later, no radio, no dome light, no keyless entry. I searched through the forums and found out that #8 fuse was to blame. I checked it, and yes, it was blown. Went to go get another, put it in and *spark* blown. Then another *spark* and blown. Had the battery disconnected, put another in and reconnected the battery, *spark* blown. What do I do now? I really don't want to take my stereo out and rewire it.
Old Oct 25, 2010 | 06:25 PM
lashlee's Avatar
You've got a pinched wire or a short somewhere. When you see a spark with a blown fuse there should be something that is touching metal. I would pull the radio first and check anything you touched.
BankWalker
Dec 22, 2015 09:18 PM
MIAMIFIT
Dec 11, 2010 05:28 PM
minnemike
Oct 16, 2009 11:24 AM
setter11
Jan 4, 2009 12:46 AM
espo79
Jun 30, 2008 03:52 PM
