Effect of different offset on handling?
Old Nov 11, 2010 | 04:30 PM
crimsona's Avatar
Not really a car guy... trying to get some answers
Have had the Fit for a while now, but decided this year to get a new set of rims for my winter tires rather than swapping the tires off my 07 Fit Sport rims every winter (both my snows and OEM all-seasons are 195/55R15 I believe)
I ordered tire rack suggested 15x6.5 rims that would fit my existing tires, not realizing the OEM rims had a 55 mm offset and the new rims a 40 mm offset.
I expect the fact it's a suggested rim from the wizard means it would work, but what should I expect in terms of rubbing and handling?
Old Nov 11, 2010 | 09:27 PM
fargasj's Avatar
No rubbing, wider track that if anything will make the car more stable, if you can notice the difference at all; weight in this particular case would make a bigger difference than the 30mm (little over an inch) overall wider stance, IMHO
Old Nov 11, 2010 | 09:56 PM
Hootie's Avatar
^ Ditto.
No rubbing at factory hieght with a 195/55R15, even with a heavy load in the car, and like previously stated the wider track will make the car more stable during cornering. If the wheels are lighter or heavier, you'll notice a slight difference (depends on wheel weight) in acceleration and braking.
Andrei_ierdnA
Mar 13, 2017 05:51 AM
Lymer
Aug 26, 2016 04:56 AM
i dnt f!t
Mar 3, 2009 04:29 PM
sirfit08
Sep 5, 2008 07:32 PM
nate9
Feb 20, 2006 03:35 AM
