Artificially Enhanced Hybrid efficiency.
Old Nov 27, 2010 | 06:57 PM
Occam's Avatar
In 2001, I almost bought a Civic HX. Thanks to light wheels, weight reduction, a lean burn engine, and tall gearing, the CIvic HX was rated at 36/44 with a stick, 40/45 with a CVT. Even recalibrated to current mileage standards, that's 31/39 and 30/36. It used a 117 hp 1.7L engine.
Now that Honda's leaders (and others) are balls deep in the Hybrid game, it seems that they pull out all the secondary tricks (low-resistance tires, aerodynamic tweaks - or in the case of the Prius and Insight, more aerodynamic forms overall) for the hybrids, and go out of their way to make the standard cars less efficient - try to find a smaller, more efficient engine in the Civic: no game. Try to buy a manual for extra economy: well just shorten those gears and let you high-rev it all day. Even the tires - why did the Civic go from using sensible 185mm tired to 205mm, but the insight is on more efficient 175's?
In 2001, a Prius was scarcely more than a hybridized Echo. The Echo's FE rating was (adjusted) 32 or 30 depending on transmission. The Prius was (adjusted) 41.
Does it seem to anyone else that they're trying to sabotage the efficiency of their ICE-only vehicles in order to emphasize the hybrid numbers?
Old Nov 29, 2010 | 07:07 PM
hondafitdude's Avatar
If they're trying to get a foothold in the hybrid game, it would come as no surprise for them to try to boost them numbers at the expense of other things. It's a marketing thing for them, and it's nothing new.
Old Nov 29, 2010 | 07:28 PM
Occam's Avatar
I'm surprised the Fit and Civic don't have lead weights attached to the undercarriage.
Lyon[Nightroad]
Oct 9, 2010 08:37 AM
percy
Jun 17, 2008 04:06 AM
ActionJG
Jun 27, 2006 08:20 PM
dancingsun
May 6, 2006 06:49 PM
MikeGR
Sep 10, 2005 12:57 PM
