heater selector not working right
Old Nov 29, 2010 | 09:02 PM
spathfinder34089's Avatar
My 2007 fit was working fine then the heater selector would not work on the defrost selection. It works on the floor and the vents that shoot air towards you and on the sides, in the dash. Works fine on all speeds. Air conditioner works. Outside air and inside air works. Just no defroster. Was wondering if anyone has had this problem?
Old Nov 30, 2010 | 12:46 PM
no issue on my 3yr old car, but sounds like your hvac cable is either worn or needs adjustment.
you can remove the glove box completely and check to see if the cable is attached correctly. check the stereo section (ICE) at fitfreak as you need to remove the cables in order to swap headunits. you'll see picts of how it's done.
Old Dec 1, 2010 | 12:59 AM
thanks for info. I took the car to dealership. They may cover this on warranty. If not I will remove glove box to see if cables are attached correctly. thanks
Old Dec 1, 2010 | 12:33 PM
yah, i remember breaking one of the knob assembly during my HU install following crutchfield's botched install instruction sheet. hahaha. had a hell of a time looking for the small ball that is spring loaded inside the knob assembly.
i ended up fixing it using very tiny screws. it's possible that your knob assembly needs to be replaced as that spring and ball could wear out as well. it's a very low tech system so should be a easy find for the root cause.
zQUEz
Nov 16, 2024 10:53 AM
lesterlai12
Aug 17, 2022 06:41 PM
Jeff Pirkey
Dec 20, 2012 05:38 PM
Kingfisher
Aug 8, 2011 07:52 PM
Alex T.
Nov 26, 2010 09:39 PM
