radio antennae removal
Old Dec 6, 2010 | 10:55 PM
phenoyz's Avatar
I dont like the radio antennae of the Fit....it looks like
Pinocchio's LONG NOSE...
Can it be remove w/out scratching/destroying the roof-top?
Thanks
Old Dec 6, 2010 | 11:44 PM
TrungLam's Avatar
Just wish upon a star, it will go away without a mark.
Old Dec 7, 2010 | 12:42 AM
Ric01's Avatar
Thanks
I've never attempt to remove the antennae before and can't advise from experience. However, you may like to check out another thread of this forum discussing the upgrade to shark fin antennae.
In the event my pinocchio's antennae is stolen (knock wood), I will change to the shark fin type
https://www.fitfreak.net/forums/fit-...y-special.html
Old Dec 7, 2010 | 03:05 AM
Krimson_Cardnal's Avatar
It can be removed, however, you'll be left with a hole in the roof. You need to remove the plastic roof latch cover in the headliner inside the rear hatch and then pull the headliner down to get a hand in there and unbolt the antenna mount. 15mm bolt holds it on, but then you'll have the hole to deal with.
Go w/ the VG Shark Fin - it's first class.
Old Dec 8, 2010 | 12:34 PM
thought it was just screwed on. the base would need to be removed and patched i think though.
trashercan
Feb 15, 2010 08:15 PM
Jazzyfizzle
Sep 14, 2008 09:17 PM
bigtoepfer
May 22, 2008 11:10 AM
DarkSniper
Aug 21, 2007 08:41 AM
BlackFit07
Sep 14, 2006 02:46 PM
