Problem with fuse
Old Dec 10, 2010 | 07:39 AM
MIAMIFIT's Avatar
Problem with fuse
I connected the air pump to the outlet on the console and blew a fuse, I've looked at the manual and checked the fuse and it's good, I've pulled other fuses and they are all good, any ideas?
Old Dec 10, 2010 | 07:55 AM
Virtual's Avatar
Which fuse did you check that you say is good? Did you check it for continuity or try replacing it?
Old Dec 11, 2010 | 02:54 PM
MIAMIFIT's Avatar
thanks for replying virtual, I found the problem, stupid me, I had a splitter connected to the plug and it has an inline 5 Amp., that is the fuse that blew.
Old Dec 11, 2010 | 05:28 PM
Uncle's Avatar
Had the same problem with my aux plug. Had a 12 volt converter plus xm radio on a splitter and it blew the fuse on the back of the splitter and melted it together. Did not blow the 20 amp fuse in the fuse box, but shorted out the back end of the plug. Pulled the plug today and took it apart and had to put more pressure on the white tab plug for the circuit to complete. The negative side I guess has some sort of fuse built into the plug.
cwbfan10
May 26, 2016 05:13 AM
SilverEX15
Jul 30, 2015 03:30 PM
oneder101
Jun 15, 2015 05:03 AM
fad3r
Jan 27, 2013 04:04 PM
ratedz
Jan 6, 2009 08:54 AM
