Accessory Socket not working
Old Dec 15, 2010 | 12:56 PM
FattyMcGee's Avatar
Hello Everyone. I have learned a lot from all of the posts on here but I have not seen any information on this problem. About 2-3 months ago I went to use my accessory socket only to find out that it was no longer working. I tried the same device in another car and it worked so it is for sure the socket. Looking at the part it only costs $20.....however.....talking to the dealer im looking at another $100 or more for them to install it. I have an 07 base model fit and i have looked at try to get the socket out but am unsure how to go about it. It appears that the whole center console area does come off (there are two screws in the back and two tab like things in the front but what about the shifter and e brake? Any help is greatly appreciated!
Old Dec 15, 2010 | 01:27 PM
spreadhead's Avatar
Check the fuse.
Old Dec 15, 2010 | 02:13 PM
FattyMcGee's Avatar
Checked all of the fuses associated with it and couldn't find one that was bad. I have read a few things on here about disconnecting the battery for a certain time and it ressetting things. Would this be an option?
Old Dec 15, 2010 | 05:32 PM
Brain Champagne's Avatar
It could possibly be just dirty contacts. If you have a voltmeter you could try slightly scratching the metal with the probes and see if you get a reading.
Old Dec 15, 2010 | 05:50 PM
viperjh16's Avatar
It comes out so easy take ur shif knob off and 4 philup screws and u have full actsis of the wires and console
Old Dec 16, 2010 | 12:33 AM
Kishore's Avatar
Check fuse 27 rating 15Amps in the Under Dash Fuse/Relay Box
By check I mean physically pull out the fuse and check with a multimeter.
Have not seen a Accessory socket go bad
Old Dec 16, 2010 | 02:18 AM
viperjh16's Avatar
Ik mines bad it's lose bc a cell phone charge get really hot and it works most oh the time
oiric2006@gmail.com
May 9, 2017 01:29 AM
Rfitfit
Dec 14, 2015 10:20 PM
MarcoM
Jan 5, 2011 08:23 PM
SpokanejdmGD3
Dec 8, 2007 07:51 PM
kyo2529
Nov 18, 2007 01:27 AM
