Honda Fit Sport GD3 Battery Replacement size.....What I did.
Old Dec 27, 2010 | 05:33 PM
geeq's Avatar
I see a lot of questions about battery replacement since Autozone, O'riely, Napa, Etc. Don't have a group size to replace it with. Instead of fitting a Civic's heavy battery in there here is what I did.
Autozone part # 8AMU1R
Is from a 99 Mazda Miata. Since they have to fit it in the trunk it's tiny. The Cranking amps are correct to start my 2007 Honda Fit Sport.
It was installed a year and a half ago. And still no problems. It needs to be vented and they give you hoses to do so. I used a factory honda 8mm screw into and existing hole on drivers inner fender and used a wire holder to mount and route the hose so it does not leak on anything important.
Here is pic of installed.
Here's a link to the Autozone battery I bought.
Battery | 1999 Mazda MX-5 Miata 4 Cylinders 1.8L MFI DOHC | AutoZone.com
Old Dec 27, 2010 | 06:31 PM
john380's Avatar
Brilliant! Thanks for the information! Although I don't have any issues with my current battery it's a good idea to plan ahead. I was looking around for another battery on Interstates site without good results. I totally forgot to check for the battery to a Miata. Thanks again!
Also, are you using a different kind of brake fluid? It looks very dark.
Old Dec 30, 2010 | 04:35 PM
geeq's Avatar
Not using any different fluid. Just havent ever changed it.
I will this weekend. The car still has OEM brakes pads and rotors with 87k on them. Still have pad left. Crazy.
Old Dec 30, 2010 | 05:58 PM
Texas Coyote's Avatar
[QUOTE=
Still have pad left. Crazy.[/QUOTE]
You drive like I do.
bargainguy
Oct 21, 2014 11:01 PM
Shortcamo02
Jun 6, 2011 01:39 AM
lnmcmahan
Dec 17, 2010 01:21 AM
spreadhead
Nov 20, 2009 09:50 PM
piclistguy@yahoo.com
May 4, 2005 11:16 AM
