The fit has more horse power per pound then the new nissan maxima
Old Jun 16, 2006 | 11:53 PM
big Fit's Avatar
I just learned that the fit has 22 horse power per pound vs the maxima of 14 hp per pound of car. It is a long story why go to fit talk and read the thread fit vs nissan maxima. I like maximas.... It sure says alot about the fit.
Old Jun 17, 2006 | 01:24 AM
hiroko12's Avatar
That may be true, but the Maxima will blow the doors off of a FIT! The Fit is a great car, but comparing it to a Maxima isn't fair (for the Fit) in terms of performance. The Fit is an economy car that feels more upscale and looks sporty and handles great. The Maxima is a top of the line Nissan that costs near twice as much as a Fit. Lets be realistic.
Old Jun 18, 2006 | 12:12 PM
jdzz's Avatar
are you sure that Horse/Lbs or Lbs/Horse?
Old Jun 19, 2006 | 10:00 AM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
got any calcumlmuations?
Old Jun 19, 2006 | 10:30 AM
NCFit's Avatar
[QUOTE=hiroko12]That may be true, but the Maxima will blow the doors off of a FIT! The Fit is a great car, but comparing it to a Maxima isn't fair (for the Fit) in terms of performance. The Fit is an economy car that feels more upscale and looks sporty and handles great. The Maxima is a top of the line Nissan that costs near twice as much as a Fit. Lets be realistic.
Here! Here!
Old Jun 19, 2006 | 11:06 AM
aziatiklover's Avatar
Master FitFreaker
I still dont feel any power tho lol
Old Jun 19, 2006 | 12:12 PM
07Fit00S2K's Avatar
Having 22hp/lb just means the Fit is pretty light. It doesn't mean it's better than the Maxima which is in a different class.
Old Jun 19, 2006 | 12:32 PM
phunklife's Avatar
yeah the figure means very little simply because once the car gains momentum is when the 270 hp is going to kill the fit. Torque from a standstill is different however.
Old Jun 19, 2006 | 12:39 PM
gettinafit's Avatar
Are you sure it isn't translated as each Fit Hp carries 22lbs, (so 109 x 22 = 2400 lbs) car weight
and that each Maxima hp carries 14 lbs, ( so 270 x 14 = 3780 lbs) car weight
That means that the engineers of Honda knew to keep the FIT light otherwise the 109 hp engine would be hauling more than 22 lbs per horse and moving NO WHERE!!
Anyone understand!
Old Jun 19, 2006 | 12:40 PM
gettinafit's Avatar
The less weight each HP is carring = more agility!! = FASTER!!
Hence the math is correct, but your deciding outcome is incorrect in understanding!
As you can see now, the maxima which carries less weight per hp will move faster!
Understand!!
Old Jun 19, 2006 | 12:41 PM
RedAndy's Avatar
You've got it backwards
It's pounds per horsepwer, not the other way around. For this comparision, lower = better. For each HP, ths Fit has to move 22 lbs, the Maxima only 14.....
Old Jun 19, 2006 | 12:44 PM
phunklife's Avatar
yes, a lower power to weight ratio = better acceleration
the ratio on the maxima is BETTER, yet lower. Plus, when you consider HP is only good ONCE YOURE MOVING, the maxima cant even be compared to a fit. Should be compared to a BMW 330.
Old Jun 19, 2006 | 10:23 PM
gettinafit's Avatar
Yes that is what BigFit wrote, hp per pound, But he got it WRONG/Mixed up!
What i said is Correct calculation! (3-4 posts up on this page!)
Old Jun 20, 2006 | 01:35 PM
NeverNZ's Avatar
hmm, at 22 hp/lb, that would be around 56,000+hp in the fit...
Old Jun 20, 2006 | 04:08 PM
carlosalicea's Avatar
He He He ....it Is Good
EMC2
May 1, 2021 12:19 PM
Dougr320
Jul 12, 2011 11:34 AM
hinher
Jun 8, 2011 09:38 AM
kennef
May 29, 2010 11:54 PM
Fit For Kielbasa
May 12, 2008 05:46 AM
