diy thread for replacing rotors 07?
Old Jan 15, 2011 | 01:19 PM
kancerr's Avatar
i snapped off a wheel stud on my 07 fit. i need to take the rotor off to replace the stud. from what ive read its only two screws that hold the rotor on? do i need to take off the 1 1/4" nut in the center to take off the rotor or just the two screws? is there any diy step by step guide for this?
Old Jan 15, 2011 | 09:38 PM
willy65000's Avatar
just the two screws and you'll likely need an impact driver (the kind you hit with a hammer) to remove them. the caliper has to come off as well but you probably figured that out.
Old Jan 15, 2011 | 09:52 PM
mxl180's Avatar
you'll probably strip the screws. then you'll need to drill out the screws.
Old Jan 16, 2011 | 08:10 AM
Carbuff2's Avatar
These screws are not critical to the brake's operation, either. Many owners don't bother replacing broken or drilled ones.
Best way to assure easy removal is to have a new one on hand.
BUT
getting back to the original problem: snapped wheel stud:
Don't you need to remove the HUB to replace the stud????
(Never done it on a Fit, specifically)
tgr23
Aug 11, 2016 05:27 PM
Hasafraker
Dec 28, 2014 10:20 PM
Sloppy_Snood
Dec 9, 2014 11:43 PM
QuackXP
Feb 15, 2010 04:48 PM
mjletts
Aug 23, 2009 09:07 AM
