Help! I am worried about fit!
Old Jan 22, 2011 | 09:47 PM
07bunnyfit's Avatar
hello,
I have a 2007 Honda Sport fit auto with 57,000 miles
The last few days I noticed that my engine service light was on
along with a thing that says
Service 123
and following with a negative number
like this -120 its up to -300 now keep going up
any help please dont have money to go to honda dealer and pay the crazy dio fees
sorry if this is the wrong forum
Old Jan 22, 2011 | 10:53 PM
DreaMv's Avatar
means you gotta change your oil
Old Jan 22, 2011 | 10:56 PM
07bunnyfit's Avatar
I just had a oil change nearly 2 half weeks ago, not sure why this would be a issue
maybe they messed up something?
Old Jan 22, 2011 | 10:57 PM
SilverBullet's Avatar
Oil, Filter,Trans service. https://techinfo.honda.com/rjanisis/...606O00355A.pdf
Buy the filter at Walmart and https://www.fitfreak.net/forums/2nd-...30k-miles.html
Old Jan 22, 2011 | 11:09 PM
The Maintenance minder was never reset. But you still need the trans service and filters (cabin,air cleaner filter)
Old Jan 22, 2011 | 11:17 PM
Texas Coyote's Avatar
They forgot to reset the oil change minder.... They may also forgotten to have changed the oil also.... I would take it back to them, put them on the spot and make them prove to you that they actually did perform the service that you were told they had... You can get a good idea if the oil was changed or not by checking the level on the dipstick.. If it smells burned or like gasoline, is not semi transparent, or feels like it has very slight gritty feel to it you need to raise hell with them.
Old Jan 22, 2011 | 11:25 PM
Brain Champagne's Avatar
This is exactly the right forum for your question. Best of luck with it. By the way, who changed the oil? Was it a service station or an oil change franchise?
Old Jan 23, 2011 | 08:25 AM
phillips9042's Avatar
The minus 120 or 300 are the miles past due that will keep accumulating until you have your maintenence minder reset. Whoever changed the oil should have reset it but looks like they failed to do it. Your owners mannual tells you how to reset it if you need it done. The same thing happened to me during my last oil change at walmart.
Old Jan 24, 2011 | 12:06 AM
Black01's Avatar
What's the update on this?
cyergey
Oct 31, 2021 02:32 PM
g fit
May 6, 2014 03:47 PM
wvucyclist
May 21, 2011 07:55 PM
shudderbug
May 2, 2010 04:39 PM
paramthegreat
Dec 11, 2009 01:07 PM
