Center Caps on Stock Steel Wheels: DIY
Old Feb 21, 2011 | 05:06 PM
TheLaughingMan's Avatar
A while back I took off my hubcaps on my 2011 base Fit and didn't like the look of the exposed and rusty axle nuts. Surfing around I saw some people sporting old school Honda emblem center caps and wanted to do it myself. I thought I'd post up my results and what I learned along the way. Hopefully this will help other people if they also want to go the route of steelies and center caps.
The bottom line here is that you can use ANY center cap that came on a Honda with the following wheels specifications: 4x100 with a 56.1 mm centerbore. This link shows the honda vehicles and years which came with this specification. Our wheels have a measurement of 2 3/16" ID and 2 6/16" OD for the hole in the middle of them.
So I went on ebay and with a bit of luck was able to sift through a lot of garbage and find the correct center caps. The seller was even kind enough to measure the "tab-to-tab" measurement so that I could confirm that it would fit. See the images below for two shots of what I purchased for about $35. There are not too many sets of these in good condition available and I'm sure with a bit of junkyard surfing you could find them for less.
Here's a shot with a closeup of a ruler layed across the top of this. It's surprisingly hard to get a good shot of the "measurement" of something, so take my word for it that the outer edges of the tabs on this cap measured 2 2/16".
Installing these was the easiest thing in the world. Just line up the cap, angle one edge of the tab into the hole and give it a good whack with a rubber mallet. Or the palm of your hand if you haven't got a rubber mallet handy. Now go buy a rubber mallet.
Before:
After:
And one of the sideview so you can see what they look like in profile.
Rock on! Have fun and save those hubcaps for nicer weather (or the next owner).
Unless I successfully "kick the habit" I'll be purchasing a set of acorn style lug nuts to clean up the wheel look further.
Old Feb 22, 2011 | 04:41 PM
Texas Coyote's Avatar
I am still waiting for somebody to get some brushed stainless steel moon disk wheel cover and put them on their steel wheels.... I increased the fuel mileage and top speed on a 82 VW diesel powered Rabbit doing it.... 54.7MPG tank after tank where it had been about 49MPG before and about another 6 or 8 MPH... I like the looks of your wheels and the idea of chrome lug nuts.
Old Feb 23, 2011 | 05:59 AM
Black3sr's Avatar
Thanks for heads up on the measurement. Mine are somewhat different. They are 76? I believe. They have a raise ridge all the way around and fit over(ie outside the wheel center) the hub. The neoprene lip was worn off most of them so I wrapped with electrical tape and pounded on with rubber mallet.
The black paint was marked quite a bit so I just soaked them in brake fluid and took it all off.
My wheels look like shit right now though. I did a poor job of painting them and a lot of it is peeling off. But is it Feb and who is checking out wheels eh.
Old Feb 28, 2013 | 10:46 AM
doane2u's Avatar
GM Chrome caps
These chrome GM caps fit my '09 base steel wheels with only a bit of modification and I like the looks. See this thread post
Old Nov 25, 2013 | 07:38 PM
xxryu139xx's Avatar
tryin to find some center caps, lots of crap on ebay and they are expensive and don't even list the measurements. anyone have a good cheap source besides a junkyard?
Old Nov 25, 2013 | 07:54 PM
13fit's Avatar
oldschool center H caps look good! Was thinking about doing this as well, but I will wait and see if I decide to keep the steelies a bit longer or not.
Old Nov 25, 2013 | 08:17 PM
Wanderer.'s Avatar
In the same boat and teetering on the edge of wheel purchase as we speak lol
Subscribed just in case.
Old Nov 25, 2013 | 09:10 PM
doane2u's Avatar
Thumbs up I have some
Read from post #58 down (click here)
I painted my wheels, added steel beauty rings, and found these chrome caps that look really good.
I have since changed the wheels and no longer need these, so will sell them cheap to anyone who wants them.. pm me if interested.
I also still have several sets of the caps that haven't been altered to fit the FIT yet and you can PM me about them as well if you don't want the beauty rings too.
Old Nov 25, 2013 | 09:23 PM
xxryu139xx's Avatar
pmed u 10 char
Old Nov 26, 2013 | 04:34 AM
Black3sr's Avatar
Those caps are sold by Mr Gasket Part number 2486. I just did mine. Great idea.
Old Nov 26, 2013 | 10:01 AM
cjecpa's Avatar
With the chrome rings if you had a dome center cap they would look similar to the new Beetle Heritage wheels
Old Jan 27, 2014 | 10:48 PM
599Ed's Avatar
CenterCaps.net - Cap Listing - Honda Details - Civic
Do these look right center caps for stock 15" steel rims?
benedictARNOLD
Jan 29, 2013 10:44 PM
constructicon
May 11, 2010 10:30 PM
diedwater
Dec 10, 2007 10:38 AM
Earthmover84
Oct 13, 2007 04:28 PM
