Back number plate light
Old Feb 28, 2011 | 04:47 AM
mfs_axis's Avatar
How do i change the number plate light... you know it's located in the back :P... one of the light is gone blfff... can't take off the light cover thingy ... HELP GUYS please :P
and this is not my car just for the review (cause can't describe it ) :P it's much more cleaner than mine... and not frozen )
Old Feb 28, 2011 | 04:57 AM
Jamy's Avatar
I take it you are talking about the ones that are next to the release handle for the hatch? If they are the same on the GD as the GE then there should be two little clips on the edges. It's easier to see if you open the hatch and hold it at an angle. I used a small electrical screwdriver to do it. Once that's done just pull the connector out the back, careful not to snap the little grabber thing off and you can replace the bulb. Putting it back in is the same just in reverse and much easier to do might I add.
Old Feb 28, 2011 | 06:25 AM
Black3sr's Avatar
1.Push the license plate light to the side to release
the retaining spring, and pull out the license plate
light.
NOTE: Be careful not to damage the tailgate.
2. Disconnect the 2P connector from the light.
3. Separate the license plate light lens and the
housing , then remove the bulb .
4. Install the license plate light in the reverse order of
Old Feb 28, 2011 | 09:23 AM
Krimson_Cardnal's Avatar
Old Mar 11, 2011 | 11:31 PM
mfs_axis's Avatar
Whooooooooooooooooooooooooooooooooopy... :P i done it... THANK YOU GUYS
LimpBagel
Jan 22, 2016 11:46 PM
veazer
May 11, 2015 03:24 PM
Rampo
New England Community
Nov 2, 2013 10:19 PM
VodkaAlan
Dec 28, 2010 10:52 AM
burnedtechie@yahoo.com
Jun 30, 2005 11:32 AM
