Stiffen Rear @ OEM Ride Height
Old Feb 28, 2011 | 09:26 PM
der Mond's Avatar
I would like to firm up and stiffen the ride and sag of my rear suspension without changing ride height. Please share any spring/shock replacement options you are aware of. Thanks.
Old Mar 1, 2011 | 10:34 AM
apexanimal's Avatar
i've tried to look into this as well... to no avail... you'd actually need slightly shorter springs since it would have a higher spring rate in order to sit at the same height... but still... i haven't found anything...
other than those inflatable bags you put inside the spring...
Old Mar 1, 2011 | 03:19 PM
der Mond's Avatar
I wonder if it is possible to find a smaller diameter spring the same height, or the proper height to install it INSIDE the original one - then all you'd need is a stiffer shock to match. Do you know of stiffer shock replacements?
Old Mar 1, 2011 | 04:05 PM
Texas Coyote's Avatar
Check out this thread and just ignore the air line stuff... This will give you the information you need to get the correct shocks and do the installation.. It is a commonly used shock size on everything from old Buick Skylarks to a number of GM front wheel drive cars. https://www.fitfreak.net/forums/fit-...-w-photos.html
Old Mar 1, 2011 | 04:22 PM
Perrenoud Fit's Avatar
^ Dito good info and can add up to 1500 lbs payload too! I like mine & it's been over a year now.
Old Mar 1, 2011 | 10:44 PM
Any heavy duty rear shock for a 2002 Pontiac Sunfire will work with stock rear springs on a GD3... The link to Manxman's DIY in my last post will show you how to do the upper shock mounts....
Old May 18, 2011 | 04:34 PM
BumbleBeeee's Avatar
Don't know if there's a way to do it without going coilover.
Old May 18, 2011 | 05:26 PM
apexanimal's Avatar
it just so happened... that autospeed just did an article on this...
Autospeed - Spring Swaps!
Old May 18, 2011 | 08:51 PM
Air bags in the springs > Firestone
Old May 18, 2011 | 09:52 PM
jadr09fit's Avatar
I've got a Firestone air bag kit waiting to be installed into the Fit. An air-line tee fitting was procured to allow filling both bags at the same time, and to de-pressurize the system in case anything causes a loss of pressure. The Air-Lift air bag kit in my Buick does a great job of hauling around 18 gallons of gas on a full tank plus 40-50 lbs of work crap in the trunk every day.
Old May 19, 2011 | 12:51 AM
I was never able to find air bags that would work on the Fit.. I opted for air strings... I had bags in the rear springs of a old Lincoln and loved the weigh they worked.. If yours work I hope you will share your experience with them, parts number and where you got them... I really want some of them.
Old Nov 9, 2011 | 10:39 PM
kmpoling's Avatar
Air Springs
I am also interested in using Air Springs to stiffen the rear of my GE8, But I need vendor and P/N's. To carry extra stuff without bottoming out.
Now using jcwhitney airlift 1000 for 2 years now, work great. P/n. A1360729. $99.00.
Myxalplyx
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Apr 22, 2015 08:45 PM
wonton2049
Sep 7, 2014 11:43 PM
cojaro
Feb 14, 2010 12:31 PM
Koi
Feb 19, 2009 01:10 AM
Mines13
Mar 6, 2007 09:13 PM
