maintence light oil life 60%?
Old Mar 25, 2011 | 01:40 PM
cfran55's Avatar
ok redo this
basically i noticed the engine maintence light on this morning
my mileage is 3600 so i was thinking this came on as a reminder to get maintence done/oil change
checked the oil life and it is at 60%
yesterday i had installed a hks axleback went smooth
other than that i have no clue why it went off, im about to go to autozone and get it checked
Old Mar 25, 2011 | 02:06 PM
spin out's Avatar
there should not be any lights going on based on mileage and oil life.
the rest i cant help you with. good luck.
Old Mar 25, 2011 | 02:14 PM
cfran55's Avatar
really i have that engine light on and i dont know why
Old Mar 25, 2011 | 02:37 PM
malraux's Avatar
Is it the Check engine light or the service due light? the service due light is the wrench. If its the CEL, then I'd obviously suspect that its whatever mod you did.
Old Mar 25, 2011 | 02:51 PM
cfran55's Avatar
alright i just got back from autozone they said the code is P0171
Fuel system too lean bank 1 (cylinder number 1 denotes bank 1)
1 - large vaccum leak
2 - Fuel system concern
3 - Ignition system concern
4 - MAF sensor faulty
5 - H02S/AF ratio sensor fault
I have a prm intake installed in december and hks exhaust which i put in yesterday around 1pm just this morning this light came on when i was on the highway.
its the check engine light
Old Mar 26, 2011 | 01:09 AM
cfran55's Avatar
bump any clue? faulty maf maybe but how?
Old Mar 26, 2011 | 09:04 AM
mole177's Avatar
yeah... not maintenance light, but a check engine light.
you prob hooked something up improperly. check all lines you touched when you disconnected them.
Old Mar 26, 2011 | 09:56 AM
malraux's Avatar
This would be my first thought. Second would be that your MAF sensor got fouled from the intake.
Old Mar 26, 2011 | 11:38 AM
cfran55's Avatar
i thought it was the exhaust aswell but all i did was unbolt the two bolt springs and the hangers bolted them back up.
this morning now the car has no cel i didnt do anything besides unscrewing the maf and looking at it to see if it was dirty then screwing it back
Old Mar 27, 2011 | 06:32 PM
swflej1's Avatar
was there a gasket for the exhaust, and have you check your intake for any oil both could of thrown a soft code (a code that pops up then goes away sometimes after the computer fixes its self).
The Barroom Hero
Mar 13, 2014 07:23 PM
bjvalencia
Oct 11, 2011 03:16 AM
xwikedonex
Sep 2, 2010 11:44 PM
DarkStorm
Aug 3, 2009 04:35 PM
FELIXY69
Oct 13, 2007 11:30 AM
