O.Z. Alleggerrita HLT Wheels available in 16"
Old Mar 26, 2011 | 07:13 PM
Blackbeard's Avatar
Question O.Z. Alleggerrita HLT Wheels available in 16"
from Tirerack.com
Received a print catalog today with these wheels in them and look pretty cool and they come in matte black, gold, white, orange, blue, red, anthracite, and matte graphite.
Not much information on them on Tirerack's site, and they don't come up as a wheel that works with the Fit.
O.Z. Alleggerita HLT Matte Graphite Silver (Tirerack)
on the O.Z. site it lists them as 6.02 kg which is 13.272 lbs.
Oz Racing - OZ Racing - I - TECH - ALLEGGERITA HLT#
O.Z. Superturismo GT is another 16 inch wheel but I couldn't find a weight, but it does come in 4X100 with a 42 offset.
O.Z. Superturismo GT Bright Silver Paint (Tirerack)
It doesn't show up as a wheel that works with the Fit either, but it should.
Neither wheel has prices on Tirerack.
Old Mar 26, 2011 | 07:20 PM
Goobers's Avatar
Did you get those specs from TR or the manufacturer?
If not from TR, then my guess is that TR doesn't have it spec'd in their database, so it won't show up as compatible with any car. Your best bet is to contact TR about it.
Old Mar 28, 2011 | 10:47 AM
Blackbeard's Avatar
Smile I found...
The specs on the manufacturers site and another wheel seller site.
I thought Tirerack would read the post and answer.
They weren't available on the weekend when I received the mailing.
The guy on the phone a minute ago was clueless.
Old Mar 28, 2011 | 11:12 AM
jim@tirerack's Avatar
Former Vendor
They are going to be 16X7 ET42 at 244.00 each. The crystal titanium color is 219.00 each and in stock. If I can help just let me know. They weigh 13.6 lbs.
Old Mar 28, 2011 | 12:10 PM
Blackbeard's Avatar
Question
Are these specs for the O.Z. Alleggerrita HLT or the O.Z. Superturismo GT?
Old Mar 28, 2011 | 12:33 PM
Former Vendor
The Alleggerita
Old Mar 28, 2011 | 01:16 PM
Blackbeard's Avatar
Question OK Jim...
These Alleggerrita HLT's are:
4 X 100?
16X7
42 offset
13.6 pounds
$244/$219 each
Is there a picture of the crystal titanium color?
Would these fit my 2010 Honda Fit Sport with Yokohama AVID ENVigor tires in 205/50R16 size?
The stock Sport Wheel is 16 x 6 with an offset of 53 (17-19lbs) (185/55R16).
Since the Alleggerrita wheels are 1 inch wider the offset would need to be lower than stock.
Old Mar 28, 2011 | 02:02 PM
Former Vendor
Old Mar 28, 2011 | 02:17 PM
Blackbeard's Avatar
Smile Jim...
These are the $219 each rims?
Do they fit my car with the tires I want?
Old Mar 28, 2011 | 03:01 PM
Goobers's Avatar
Wow, that's very competitive with Enkei RPF1s. Similar weight, size and price (different style though).
Old Mar 28, 2011 | 03:22 PM
Blackbeard's Avatar
Smile Here are...
Enkei RPF1 Specs
16x7
$219 / each
Offset: +43mm
Backspacing: 5.66"
Bolt Pattern: 4-100
Rec. Tire Size:185/55-16
Weight: 13.7 lbs
Former Vendor
I checked the clearances and unfortunately they hit the brake.
Sorry,
Old May 5, 2011 | 10:02 AM
animes2k's Avatar
Sorry,
I realize this is a little old, but would the Superturismo GT 17" fit the 09 Fit?
What size tire would work without rubbing?
Would it work if lowered (SWIFT springs, ~1" drop)
Prices/links?
Thanks!
Old May 5, 2011 | 10:18 AM
Former Vendor
Unfortunately they do not work on the car.
Old May 7, 2011 | 12:36 AM
SleepyNyte's Avatar
Did you check both the GD3 and GE8 or just GE8?
Old May 7, 2011 | 01:48 PM
Former Vendor
They just do not clear the brakes on the Fit do to the spoke design.
2Legit2Fit
Jun 16, 2010 04:00 PM
Pere
Feb 7, 2010 05:40 PM
annunC8
Jan 31, 2010 10:02 PM
radareclipse
14
Nov 30, 2009 09:16 PM
phunklife
Jul 28, 2009 07:32 PM
