Morimoto Mini D2s Bi-Xennon retro GD3
Old Apr 2, 2011 | 06:45 PM
gym's Avatar
gym
Basic mini retro... I am using ddm ballasts, Morimoto D2S 4300k bulbs, Mini D2s projector and TRS harness...
I painted the headlights JDM black, I used the apollo shroud some slight trimming was needed.
Mini D2s and shrouds
Rule #1 test your projectors
Painted the reflector silver to reduce glare but still have an oem look
The projector and shroud mounted
Remove bumper and lights
Hook up your harness and mount your ballast.
At this point check your horizontal alignment!!!!!! And your connections, otherwise test everything...
Seal them up I did 250 and 8 min but everyone has a different idea on this one.
Here they are mounted...
Every thing except the ballast are from Matt and Nate at The Retrofit Source
Trs rocks output pics tonight...
Old Apr 2, 2011 | 09:21 PM
gym's Avatar
gym
Low beam and high beam output pics from 25 feet. The parking lot was on a slight slant, and the hot spots above the high beam are glare off of the shield... They are a tad wider then the pic there was a dumpster to my left
Old Apr 2, 2011 | 10:28 PM
danger69's Avatar
Nice job. welcome to the retrofit club.
Old Apr 2, 2011 | 10:35 PM
jdmjunkie561's Avatar
Damn great job !!! U wanna do mine ? Lol
Old Apr 4, 2011 | 12:08 AM
gym's Avatar
gym
Thanks Danger69, Jdmjunkie561 if you lived in MD I would... I will go on record anyone in the baltimore area that wants to step away from pnp in the stock reflector, I will help you all though it is easy, if you can put on a intake you can do this!!!!!!
Old Apr 4, 2011 | 01:34 PM
accordguyintake's Avatar
sir, i believe you have just inspired me
Old Apr 4, 2011 | 06:40 PM
Koi's Avatar
Koi
Great job, makes me want to do the same thing now...
Old Apr 4, 2011 | 07:30 PM
danger69's Avatar
Koi - Its not as hard as everyone thing it is. Truthfully the hardest part is just opening up the headlight. The glue on these damn headlights are crazy tight. But after that its easy sailing.
Old Apr 4, 2011 | 07:35 PM
sometimesjoe's Avatar
Agreed! Sticky glue that is hard to come off if you get it on anything!
It came out good there! Took me a few tries to get it lined up on my GE with the same setup. Still tweaking mine here and there when I have time to get the rotation perfect.
Old Apr 4, 2011 | 08:46 PM
gym's Avatar
gym
Yeah the hardest part is getting them open, after that it is cake. Thanks sometimesjoe... I would love to have some Orsam CBI's but they are around $200 and are not in the USA yet. It is rumored when released in the USA they will be Silverstars, 5000k very little color shift and 3400 Lumens. The Morimoto bulbs are nice though but no aftermarket bulbs can compete with OEM...
Old Apr 4, 2011 | 09:54 PM
Wait till TRS come out with their new Morimoto line. The bases look like Phillips. I'm using 85122+ and I'm pretty happy with the performance. I'll wait for the output shots of the new Morimotos and get them as backups.
Old Apr 4, 2011 | 10:43 PM
Koi's Avatar
Koi
There's just something about putting the headlights in the oven that I feel iffy about, but if I'm confident working on much more integral parts of the car myself then I don't see why I can't do this. Just need the cash as usual
How do those 4300k bulbs look in person? Clean white or more towards yellow?
Old Apr 5, 2011 | 02:10 AM
4300 should have a slight hint of yellow, but I like that 5000k would be pure white
question though, what could I use to add more sealant when I put the lights back on? I've taken my headlights off once to paint the bezel black, but now it leaks
Old Apr 5, 2011 | 09:30 AM
gym's Avatar
gym
butyl tape, I got a roll from TRS If you dont see just call and ask Matt
Old Apr 5, 2011 | 09:32 AM
gym's Avatar
gym
They are way more white then a halogen, I think they will be perfect when they color shift a bit...
Old Apr 5, 2011 | 10:13 PM
gym's Avatar
gym
Sometimesjoe I just saw the new mori 3fives on hidplanet and you are right they look just like phillips, even the red salts in the 6000k...
Old Apr 9, 2011 | 07:12 PM
isthata_scion's Avatar
I still have my set of ssm headlights sitting around. Retrofit them for me please? LOL
Old Apr 10, 2011 | 03:38 AM
danger69's Avatar
Koi - What I would do is set your oven for 350 degrees and put the headlights in for 4-5mins. Take them out and try to pry them open. If you can't do the first time put the headlights in the oven for 1-2 minutes. It takes a lot to melt the headlight. As long as your careful it should be fine.
Old Apr 14, 2011 | 12:05 PM
gym's Avatar
gym
To add to what danger said make sure none of your brackets are touching the rack and work with the lens down while opening... The brackets are real easy to bend and break!!!! Ask me how I know lol
Old Apr 14, 2011 | 12:29 PM
i would also say turn off the oven while the headlights are in! just heat it up to yuor perferred temp and shut it off, the last thing u want are melted headlights!
