Aircon dead!!!
Old Apr 30, 2011 | 12:06 PM
Tapiwa's Avatar
Aircon dead!!!
Hi. I live in Zimbabwe and right now the weather is burning the skin right of your bones!!
As I was driving yesterday, with the cool breeze of the AC whistling past my ears, suddenly, the breeze turned it into a hot wall of hellish fire! For no reason I cant get cold air!!!
The A/C light on the dashboard still lights up and I even hear the fans kick in when I press the button. This is leading me to think that maybe its something wrong with the refrigeration side of things because there is usually that click that comes every minute or so when you have the AC on but its now gone. And when I switch on the AC the rev meter increases slightly for about 3 seconds instead of the usual decrease in revs meaning that the computer side is fine as the car is compensating for the impending load of the A/C system.
I had a quick test for gas yesterday and the meter read fine.
So do any of you have any idea of what could be going on with the A/C because I'm hoping its not a major problem as I can only access a mechanic in about a weeks time!
Thank you.
Old May 11, 2011 | 10:32 PM
Black01's Avatar
Thank you.
Get your freon recharge to get your cold air back.
Old May 12, 2011 | 06:04 AM
soumilpaul's Avatar
same problem me to facing any solution please............
Old May 12, 2011 | 02:48 PM
Tapiwa's Avatar
Thanks for the reply...will a lack of freon gas just immediately make it stop blowing cold air?...because it did seem to be cooling quite normally until it suddenly blowing the "magical" air :-)
Old May 12, 2011 | 02:59 PM
Yokomohoyo's Avatar
Check your filter located behind the glove box. It may be clogged.
Old May 13, 2011 | 02:46 PM
Tapiwa's Avatar
Ok..I'll have to check that tomorrow morning because Im just about to sleep...is it particularly hard to find or is one of those things you can't just miss?
Old May 13, 2011 | 03:02 PM
Yokomohoyo's Avatar
It's simple open the glove box and press and hold the edges inwards and gently pull it outwards. You'll see the filter their. And rule if thumb if it is white or cream its ok. If its brown or darker that means change it as soon as you can.
Old May 13, 2011 | 09:47 PM
Black01's Avatar
[quote=Tapiwa;992634]Thanks for the reply...will a lack of freon gas just immediately make it stop blowing cold air?...quote]
The answer is yes.
lief101
Apr 22, 2017 05:34 PM
jlatus
Oct 7, 2012 10:06 AM
jlatus
Jul 24, 2012 07:24 PM
cruzn246
Jul 11, 2012 08:32 PM
Jisch
Aug 26, 2006 03:13 PM
