B 1 3
Old May 4, 2011 | 11:35 AM
D50boy's Avatar
B 1 3
I had B 1 3 come up on my way to work on the maint system. I'm not around my book at the moment.... can anyone tell me what I'm up for?
Oil change and rotation?
Thanks!
Old May 4, 2011 | 02:50 PM
Koi's Avatar
Koi
B
Replace engine oil and oil filter
Inspect front and rear brakes
Check parking brake adjustment
Inspect tie rod ends, steering gear box, and boots
Inspect suspension components
Inspect driveshaft boots
Inspect brake hoses and lines (including ABS)
Inspect all fluid levels and condition of fluids
Inspect exhaust system#
Inspect fuel lines and connections#
Rotate tires
Replace transmission fluid
Driving in mountainous areas at very low vehicle speeds results in higher transmission temperatures. This requires transmission fluid changes more frequently than recommended by the maintenance minder. If you regularly drive your vehicle under these conditions, have the transmission fluid changed at 60,000 miles (100,000 km), then every 30,000 miles (48,000 km). (For A/T only)
If you tow a FIT behind a motorhome, the transmission fluid must be changed every 2 years or 30,000 miles (48,000 km), whichever comes first. (For A/T only)
JanFit
Nov 30, 2015 02:58 PM
Terry M.
Apr 9, 2014 09:50 PM
zukered
Dec 10, 2013 07:19 PM
AJR Jay
Jan 5, 2011 06:57 PM
FELIXY69
Aug 27, 2007 09:32 PM
