What kind of anti-rust do you use?
Old May 8, 2011 | 12:04 AM
Fitter123's Avatar
Got a new Fit this week and I am wondering what should I do about rust. Paid like 500$ for Honda wax, but I was wondering if oil anti-rust, like Krown, is an option. I am not sure about having my brand new car drilled and I have read there may be some problems with the oil interacting with the rubber...
Where I live it is damn cold in winter and lot of salt everywhere. I need anti-rust, but getting the best one isn't easy...
Any idea?
Old May 8, 2011 | 12:13 AM
hyperfit's Avatar
I've had some "rail dust" in the paint after winters, a clay will clear up most of it.
For a rust preventative, Krown seems to be a good option. There's a lot of DIY products for the undercarriage too. Fluid Film seems to be excellent.
Old May 8, 2011 | 12:26 AM
Fitter123's Avatar
What about Krown and rubber? I have read that it can litteraly destroy the rubbers... Maybe it's not that important as rubbers are cheaper than a rusted car?
I was also considering getting wax (but not from Honda dealer), but my feeling is that oil can go in places where wax can't...
Old May 8, 2011 | 05:19 PM
jjrbus's Avatar
Back in the old days when I lived up north. We used a 50/50 mixture of 30 weight oil and kerosene as time went by lamp oil (deodorized kerosene with scent added) was substituted for the kerosene.
Plastic plugs were bought and holes were drilled in strategic places, a garden sprayer was used to apply the mixture. It was also liberally applied to the entire under carriage of the vehicle.. I believe newspaper was draped over the exhaust system by some? This was done once or twice a year.
There are 2 people left that I know of that did this. They have 30+ year old rust free vehicles!
HTH JIm 0311
Old May 8, 2011 | 06:36 PM
hyperfit's Avatar
I'd check with Krown, but I'd think they'd want their product to be safe with rubber components.
Old Jun 12, 2011 | 11:54 AM
FanOfFit's Avatar
I've been using Krown on my Ody x 10yrs in southern ontario, no rust engine or body (the only place that has rust is inside the van!!!). I rarely wash the van other than when Spring starts when salt and warmer temperature is harder on the metal (silver is great at hiding the salt dirt!!), and get it spray in late summer when warm. Messy but works.
Old Jun 12, 2011 | 03:16 PM
Virtual's Avatar
I've had great results with Antirouille Metropolitain (see pic in sig).
Check it out if you're in the province of Quebec: http://www.antirouille.com/en
Old Jun 12, 2011 | 07:15 PM
Paul56's Avatar
Any idea?
My profile says I'm in Texas so one would assume I know nothing about Canada, snow and salt, but to the contrary... I spent many years in Canada dealing with all this.
How long do you plan on keeping the vehicle?
The new vehicles are designed to be more resistance to corrosion than the older ones used to be. If it was me and I still had a vehicle in Canada I would not bother with rust treatment. The holes that need to be drilled for an effective treatment are new points themselves where rust can start.
Old Jun 13, 2011 | 06:26 AM
Black3sr's Avatar
Any idea?
Where in Ontario you two?
I had mine undercoated by the dealer when I bought it. Seems to be just fine. Only think is when you open the hood it is not nice and shiny as there is a fine coating on a lot of the painted parts as it should be.
bill
Old Apr 11, 2013 | 04:10 PM
Fitter123's Avatar
Follow-up
Been using Krown for two years now (twice a year) and the rubber bushing around the trunk is starting to swell. I spray silicon whenere I can (I've read it helps) but still it su*ks.
Old Apr 11, 2013 | 05:32 PM
solbrothers's Avatar
I don't use any
Old Apr 11, 2013 | 05:37 PM
i use rustoluem paint on the under carriage from time to time when i see surface rust, but other then that no need for further rust protection.
i put a dab of motor oil on a lot of the exposed bare metal bits in my engine bay and that seemed to work real well for our salty winter weather.
Old Apr 11, 2013 | 09:28 PM
Steve244's Avatar
KY Jelly. What?
Old Apr 12, 2013 | 01:28 AM
loudbang's Avatar
I don't use any
And it shows
Old Jun 6, 2013 | 09:41 PM
dll932's Avatar
Not all treatments need holes to be drilled. Mine (MiracleShield) didn't. I had extra put on underneath for sound damping.
Old Jun 7, 2013 | 08:14 PM
CasualFitOwner's Avatar
+1 on rustoluem paint.
I usually clean and paint over any signs of rust on the underside.
During winter, when driven over salt for a while, I usually take the car to car wash and power spray the underside to try to remove as much salt as possible.
Old Jun 7, 2013 | 08:18 PM
best way is to wash the under carriage using a lawn sprinkler after winter. yah funny as hell, but it works. place your car on ramps and run a sprinkler for 15min for the front, 15min for the rear.
after all dry, then check for surface rust. wire brush it off, clean it, and spray (or with brush) rustoleum. that's about all it takes to keep the car nice for a long time.
also, during the winter, try to keep your car as dry as possible. salt by itself doesn't do much damage. it's when you introduce water it completely accelerates the corrosion.
but these cars are imo made to last at least 5-6 years with partially neglected use so im sure with a little care, it can last 10+years easily.
two_way_mirror
Oct 24, 2011 04:15 PM
jnesselroad
Sep 26, 2011 02:55 PM
MiMi1
New Jersey Community
Sep 10, 2010 10:18 PM
cruiserandmax
Jan 18, 2010 10:44 PM
coldstorage5
May 4, 2006 08:10 PM
