Sponsored by:
Sponsored by: CARiD
Window problem
Old May 8, 2011 | 03:35 PM
awsiany's Avatar
Window problem
hi im in desperate need of help. I have a 2003 jazz and the drivers window will only go down the switch is not making it go back up. all plugs and wires seem to b ok. any suggestions
Old May 8, 2011 | 06:58 PM
Krimson_Cardnal's Avatar
Most likely in the motor.
You might try resetting the control unit:
1. Turn the ignition switch to LOCK (0).
2. Press and hold the driver's window DOWN switch.
3. Turn the ignition switch to ON.
4. Release the driver's window DOWN switch.
5. Repeat steps 1-4 three more times.
Old May 9, 2011 | 05:41 PM
Did this ever work?
Old May 13, 2011 | 10:36 PM
jeon's Avatar
alcohol method
This has happened to my Honda Accord before.. I was about to buy an OEM Honda parts to replace my switch until I read the alcohol method. Dumping alchohol down the switch until it gets all inside, then try to work the switch back and forth in order to clean the contact. It really worked for me.. I don't think you have a problem with your motor since your window still goes down-meaning your motor is still working..
Old May 18, 2011 | 04:25 PM
BumbleBeeee's Avatar
IF that doesn't work, depending on how confident you are with electrical, you may want to take apart the switch and see if the contacts are dirty or need to be re-soldered.
Old Jun 1, 2011 | 07:03 AM
Jason Smith's Avatar
jeon is right. Alcohol method works like a charm even for me.
Also, Motor may have problem considering the type of rotation is it being able to perform. One sided rotation of motor blades can be one of the reasons.
Old Oct 9, 2012 | 09:04 PM
RogueCreature's Avatar
hmm. my left front window is sometimes slow to open and sometimes normal speeds. all others are normal....
i once let a $20 bill slip inside the door via the window.
how would i open it up to get the money out and see what the hell is wrong with it?
thanks for input
Old Dec 14, 2012 | 11:18 AM
Alfie077's Avatar
Well I think you should check the window motor gear. I think the gear is completely bad ass. So you need to check and if its finished then replace it with the new one. hope you understand what you have to do. now go and fix it. gud luck.
Old Dec 14, 2012 | 03:55 PM
Houston hb's Avatar
silcone spray the window tracks, might be getting caught on the rubber drying out.
Old Dec 22, 2012 | 07:12 AM
Fletcherz's Avatar
i think the windows have got corrupt its better to reinstall the new version of them..
Old Mar 14, 2013 | 05:15 AM
spedg55's Avatar
It's not a gear problem. Mostly with such problems don't work the button. If you didn't check it - you have to. When the up-button contacts inside are broken - the window will go only down. So try to check this.
Old Oct 27, 2014 | 09:25 AM
monty77's Avatar
I have also same problem
rocksnap
Jul 27, 2024 01:59 PM
fitowner10
Aug 22, 2016 09:53 AM
Santiad
Dec 8, 2015 08:48 AM
Boodee
Aug 12, 2015 12:27 AM
Body2Big
Jun 16, 2014 03:14 PM
