fitfreaks: help me troubleshoot this annoying sound
Old May 13, 2011 | 02:41 PM
Santiad's Avatar
Its a buzzing sound (metallic) which occurs around 2500 to 3200 rpms but matches gear shifts : when I shift is disappears for a split second but comes back in
Also this sound only occurs while driving: I tried replicating it in neutral, park, and even drive while e bake and regular brakes where held down (not safe and couldn't get to 3k rpms without pulling)
Any ideas? It seems to strike out exhaust as a possibility right? Or am I.missing something?
I'm looking at either exhaust or tranny as the culprit but need as much info from you all as possible before I bring it in.
Please help, I'm sure it would help someone else someday. Thanks!
Old May 13, 2011 | 03:46 PM
doctordoom's Avatar
Supervillain
is the buzzing there when you rev it to the 2500-3200rpm range in neutral?
if it is, it could be the heat shield(s) rattling. you can try tightening the heat shield bolts on the exhaust manifold and/or the heat shield bolts on the catalytic convertor.
i had that sound and it was an easy fix, now my car doesn't sound like trash haha
Old May 13, 2011 | 04:49 PM
Santiad's Avatar
No I can't get the buzz in neutral though if I can get the up high enough I'll check the shields.
Old May 13, 2011 | 08:42 PM
Santiad's Avatar
So I was able to jack the car up and check the cat heat shield by tapping it with a pole. It didn't seem loose. I also confirmed the sound can't be relicated in neutral (got it to 4.5k rpm no sound.
Could it be the transmission?
Old May 13, 2011 | 08:47 PM
mole177's Avatar
can you reproduce it on demand?
Old May 13, 2011 | 09:07 PM
Santiad's Avatar
Yea so long as I am driving, it can be reproduced as soom as the tach hits 2500 rpms and stop just before I hit 3500. Continues even if gears shift so long as I am in the rpm range.
Old May 13, 2011 | 09:31 PM
mole177's Avatar
you still under warranty ?
Old May 13, 2011 | 10:20 PM
Santiad's Avatar
No. Unfortunately I got 62k miles. Performed the lms recall at 61k.
Old May 14, 2011 | 02:12 AM
doctordoom's Avatar
Supervillain
hmm, i was able to reproduce my heat shield rattle while revving in neutral, but if you're game, go ahead and try tightening some of the bolts - you can't tell if they're loose by tapping on the heat shields, but if they are indeed loose, you will know when you turn the wrench. they just vibrate at a certain rpm range, enough to cause an audible rattle.
good luck, i hope that solves it
Old Nov 5, 2011 | 07:45 PM
Sideways's Avatar
I have a similar sound while driving, but it is right around 3,000 RPM. I have a 2007 Fit, 5MT. The sound happens in any gear, either when shifting, decelerating in a gear, or in neutral. It is most audible when driving. I made sure the exhaust manifold heatshield was tight but I have not checked the catalytic converter. The sound has been happening for a couple of months now. Definitely weird how it is at a specific RPM range. I will check more bolts/exhaust connections. Any other ideas?
Old Nov 5, 2011 | 10:18 PM
Santiad's Avatar
mine went away
Hello, its been awhile but mine eventually went away.
I'm not sure what it was but did notice a few things were off:
1) Plastic bag melted to exhaust after cat and turned to droplets. Shaved as many of those as I could with a razor and it helped.
gkitf16
Apr 16, 2019 06:41 PM
alvinchua
Mar 1, 2014 02:12 AM
Nvillegas
Mar 7, 2013 02:12 AM
get_FIT
Oct 26, 2010 12:34 AM
PwRmAd
Jul 13, 2007 11:22 PM
