1992 Honda Accord station wagon, wont run
Old Jun 2, 2011 | 02:39 PM
Carnewbie99's Avatar
Hey all!
This is my first time here on any car forum of any kind. I have recently bought a 92 honda accord station wagon, and just the other day i was driving and my car stopped running. I tried to start it again, and the engine made noise like it was trying to start, but it was unable to do so. It's not the battery; lights/radio work fine and its new. My neighbor who came to help me said it might be my coil? He stuck a screwdriver in a couple of my plugs and said that there is no spark. I have a scanner but i cant seem to find where to connect it to. I looked elsewhere and saw that it might be under the glove box but when i look under the carpet there i see a big metal cover bolted down.
Basically i'm trying to figure out where to plug the scanner into. Also, any ideas on what i could do to try and fix it would be a big help.
Thanks,
Jim
Old Jun 2, 2011 | 08:00 PM
grtpumpkin's Avatar
A code reader won't really help you out unless the Check Engine Light is on. If the CEL isn't on that means there aren't any codes to be read. Check the voltage of your battery with a multimeter, or take it out and get it to Advance auto and have them check it for you. Just because the lights and radio work does not mean the battery has enough charge to start the car. If the engine is turnng over but won't fire it could be a bad coil, but it could also be about thirty other things as well, including a clogged fuel filter. How many miles does the car have on it? When was its last major service, and who did the work?
Old Jun 2, 2011 | 08:24 PM
94si's Avatar
ENG: Diagnose a Check Engine Light and S/D4 errors. - CB7Tuner Forums
thanks the teams at cb7tuner for a very good info
hope this help
Originally Posted by aero
After 19,000 threads about how to do this, I decided there was a need for one of these. I thought there was one.. but I dunno. Motion to sticky :p... mods if you wanna change the thread title to "how to .... " that would be kew.. i forgot to add that.
1. If your check engine light is on, start by going to your passenger side kickpanel.
There should be a blue connector w/2 wires to it like the one pictured below.
Put a paper clip, wire, connector in it to connect the two prongs.
2. Put the key in the ignition, and turn the key 2 clicks to the acc on, where all the lights light up on the dash.
3. You will now watch how many times the CEL light blinks.
a long blink = 10
a short blink = 1
It will repeat after all the codes are done.
4. Compare to this list to see what the problem is:
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
Resetting ECU
1. Disconnect Negative battery terminal (never only take off the positive, cuz it can kill the battery when it grounds all the power out, if left for a while)
2. Look in the Underhood fuse box, find the "Hazard" Fuse. Pull it out.
3. Let the car sit for 10-15 minutes
4. Reattach neg battery terminal and put fuse back in
5. Restart car w/nothing on (radio, lights, a/c) and just let it run for a few minutes.
6. Turn off, and then it should be good to go.
TCU Error codes are indicated by the "S" light on 90-91 models, and the "D4" light on 92-93 models. The codes can be read in the same way, with paperclip method, as the ECU codes, by counting the flashes of these lights.
The error codes are as follows:
0-Transmission control unit (TCU) faulty.
1-Lock-up solenoid 'A' circuit open or shorted.
2-Lock-up solenoid 'B' circuit open or shorted.
3-Throttle Position Sensor circuit open or shorted.
4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
5-Shift Lever Position Switch circuit shorted.
6-Shift Lever Position Switch circuit open.
7-Shift Solenoid 'A' circuit open or shorted.
8-Shift Solenoid 'B' circuit open or shorted.
9-Counter shaft or transmission speed pulse generator open or shorted.
10-Coolant Temperature Sensor open or shorted.
11-Engine RPM (Ignition coil signal) open or shorted.
12-(No code 12 used)
13-Main shaft speed pulse generator open or shorted.
14-Linear (line pressure control) solenoid open or shorted.
15-Kick down switch circuit shorted.
__________________________________________
ABS Error codes
Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST - CB7Tuner Forums
Originally Posted by evil_demon_01
This thread is for all the my car just died / doesn't start problems.
An engine needs 3 basics things to run - Fuel, spark and compression.
Timing is also a factor, but incorrect timing can still result in a running engine (although more than likely it will run rough) if far enough out it will not run at all.
To check for fuel:
Fit a fuel pressure gauge and check the pressure.
Pressure should be:
35-41psi with the engine idling, and the vacuum hose of the fuel regulator disconnected
29-35psi with the engine idling, and the vacuum hose of the fuel regulator connected
If you don't have access to a fuel pressure gauge, crack off the 10mm bolt on the fuel feed line, if fuel is coming out then you have fuel at the injectors inlet.
NOTE - This does not necessarily mean the injectors are firing.
To check if the injectors are working, you can listen to the solenoids inside them by holding a screwdriver on them and listening for the clicking sound.
To check for spark:
Remove the plug leads, and put an old (but working) sparkplug into the lead, then ground the tip of the sparkplug on a suitable ground.
Have a friend crank the engine while you watch the sparkplug.
If you see a spark jumping the gap, you have spark.
If not, either the sparkplug isn't grounded correctly, or there is a problem in the ignition circuit.
To check for compression:
Get a compression gauge, and fit it into each sparkplug hole one by one.
Wind the engine over for 6-8 compressions and take the reading.
Compression for F20/F22 should be:
Nominal -178psi
Minimum - 135psi
Maximum variation between cylinders - 28psi
To check Static timing:
Remove rocker cover and top timing belt cover.
Set the crank at TDC (white pointer on the flywheel)
If the static timing is correct, the cam pulley should have the arrow pointing up, and the two marks 90 degrees to the left and right of the "Arrow/UP" should line up with the head.
My car doesnt crank:
- Check the Battery
- With ignition at crank position, you should be getting source voltage at the one wire circuit on the starter,
- Check for source voltage at the positive post on the starter
If you have voltages at both and still doesnt do anything, listen for a click. no click? gently tap the solenoid (small cylinder)
Nothing? Replace the starter.
If the starter sounds like it wants to go but doesn't
- Check connections
- Recheck battery
- Check for a locked up motor
If the starter spins but makes a grinding noise
- Check flywheel/flexplate ring gear for wear
- Check starter drive gear for wear.
No fuel
-check if there's actually fuel in it
-check for pinched line or clogged filter
-check for fuel pump buzz at key up
-operation of main relay
-incorrectly hooked up fuel gauge. i use the OTC fuel gauge setup with adapter 68.
No spark
-check at coil, if good at coil replace cap and rotor.
-test light on positive and with cap off for internal coil, place on negative end of coil. Have someone turn the engine over, the test light should blink rapidly. if no blink or intermittent...check ignitor, positive end of coil for battery source and signal from ecu.
-if no power at coil + which is the blk/yellow wire, check ignition switch for power and main relay
Old Jun 2, 2011 | 10:29 PM
gd3vbp's Avatar
So you joined a Fit forum to fix your cb9. Excellent choice noob. You must be trolling.
score04w's Avatar
They see me trollin, they hatin.
white_FIT2012
Nov 28, 2017 05:56 PM
lincw@yahoo.com
Oct 28, 2011 02:44 AM
jmattis@attglobal.net
Jul 11, 2005 12:05 AM
caroline_t
May 28, 2005 04:41 PM
ibcarolek
May 4, 2005 11:16 AM
