diy hr shifter box in fit
Old Jun 5, 2011 | 12:32 AM
breadman's Avatar
thanks to hybrid racing and jeff and matt at east coast performance for helping with this. this is a basic run down of how you mod a hybrid racing shifter box for a 07-08 k swap fit, iam useing a type s tranny.
here is what we started with, not useing the bottom part cause it allow better access to the bolt holes on the tunnel
then you need to cut the box in the back down to the first tabs on the bottom, leaving just enough at the top of the back so the tab holding the spring isnt sticking out, this is cause the tunnel is at an angle in the fit
next take few metal bars and use a bench press and bend it to the contour on the tunnel in the car, take the rubber tabs with metal rings out of the stock shifter box and weld them to the new tube frame, take your time with this so the bolt holes will match up.
next put the tube frame and shifter in the car and put the console over it so you can get the shifter to position in the console as needed, it will be a little forward then the stock postion but will still go in the shifter boot easily, and needs to be angled down just a hair to clear the cup holder section, take a marker or sharpy and mark on the tube frame where it needs to be welded at
now weld the box to the tube frame at the mark you made, make sure to make a line when making the mark so that you get the box at the needed angle
then take a metal strap bar, got it from lowes, and cut two sections that are from the tube frame to the top of the sides of the shifter box, then weld away, clean up
then bolt everything up in the car, put console back on, set shifter at height and postion you want, in this pic iam in first gear, then drive and enjoy!!
Old Jun 8, 2011 | 03:52 AM
kodok3ribu's Avatar
maybe my eyes are blurry.. but is that stick not inline with the original stick? eniwei that shifter is really awesome.. i hate the plastic stock ones...
Old Jun 22, 2011 | 11:30 PM
breadman's Avatar
that cuz i had it in the first gear position, its a hair off from the stock position but not enough to notice when driving, the way our shifter tunnel contours and all the stuff in there that in the way limits doing but so much
Old Aug 24, 2011 | 12:37 PM
OddMarz's Avatar
dope, I love it
Old Aug 24, 2011 | 09:40 PM
kylerwho's Avatar
spoon fed
going to save this so i can use it later. great write up.
seanriogd1
Feb 27, 2019 08:01 PM
FELIXY69
Oct 4, 2010 07:12 PM
strmslvrfit
May 25, 2009 03:54 PM
No_Skillz
Feb 17, 2009 01:09 PM
xanatos
Aug 26, 2008 11:06 AM
