"Wheel Bearing" noise coming from Fit after lowered for 2 weeks?
Old Jun 8, 2011 | 01:15 PM
pearl's Avatar
Trying to get to the bottom of this. Kind of annoyed. Lowered my car about 2 weeks ago and this just started.
Facts:
-2008 Sport, 29,800 miles.
-Skunk2 Springs on stock struts.
-No wheel alignment, yet.
Symptoms;
-Only during deceleration, will NOT make noise when I am accelerating.
-Not motor/trans related, I can be in neutral and rev, sound does not change.
-I have yet to take the front wheel off, but the sway-bar endlinks feel firm.
Is this a bad wheel bearing? After a little research it seems like these wheel bearings suck.
I'm going to take the wheel off and tighten everything down and make sure it looks right, but everything look and feels stiff. When it was first lowered, it made no noises.
Thanks.
Old Jun 8, 2011 | 04:54 PM
apexanimal's Avatar
does it get louder when you're turning in one direction or the other?
that would be the other test to determine if it's a wheel bearing... and which one...
Old Jun 8, 2011 | 08:50 PM
pearl's Avatar
doesn't make any noise differently when i turn the wheel either direction.
Old Jun 8, 2011 | 10:02 PM
apexanimal's Avatar
you're moving when you're turning right? in doing this, you're basically loading each side to see if it replicates the sound you're hearing when you brake... do this while going highway speeds...
if it still doesn't do it while doing the above, it's most likely something brake-wise...
Old Jun 8, 2011 | 10:03 PM
vtecfit1's Avatar
might be brakes on wear tabs, seems kinda soon under 30K
also front or rear?
Old Jun 9, 2011 | 06:41 PM
pearl's Avatar
this noise is in the front drivers side.
i jacked up the car and shook the wheel before i took it off. no play. i retightened everything. end links are tight. everything looks tight. i checked the threads on the top of the struts, and they are showing the same amount of threads on each side. i went to yank at the spring and realized it wasnt sitting in the strut right. i twisted it maybe an 1/8th of a turn and it is now sitting in the strut correctly.
i didn't want to take the whole strut out, so i figured my troubleshooting would stop here. i put the wheel on, SAME NOISE. balls.
any other tips?
Old Jun 9, 2011 | 08:07 PM
apexanimal's Avatar
does the noise go away when you lightly apply the brakes?
Old Jun 9, 2011 | 09:28 PM
pearl's Avatar
yes, it will go away after a second or two of the brakes being applied...
but shouldn't i hear that noise when accelerating?
Old Jun 9, 2011 | 10:39 PM
da9r00d's Avatar
its the wheel bearing, i had the same problems/symptoms, changed the wheel bearing and its good. it was my front drivers side. when i looked at it the bearings were all out of place and the plastic retainer was in pieces
Old Jun 10, 2011 | 08:49 AM
pearl's Avatar
thanks guys, ill look into the wheel bearing. is this covered by my warranty? i have the car lowered, but would be willing to swap out the suspension to get this fixed.
Old Jun 10, 2011 | 10:00 AM
apexanimal's Avatar
it's not covered... considered a wear item...
sneaky_flute
Jun 1, 2021 04:03 AM
mxl180
Feb 7, 2014 07:54 PM
xcsp800
Feb 7, 2014 01:26 AM
single_digit
Feb 14, 2013 11:56 AM
Solscud007
Dec 20, 2012 11:03 AM
