Running RCA cables?
Old Jun 14, 2011 | 06:07 PM
danger69's Avatar
Running RCA cables?
I was wondering which is the best/easiest way to run the RCA cables? I have a 5 channel amp with components. Should I run it on the door sills or down the center?
Old Jun 14, 2011 | 09:58 PM
Jamy's Avatar
Door sills are the easiest they just pop out and off and zip tie it to the wire loom that's already there. That's what I did at least. I would have taken out my seats to run it down the center and I didn't feel like putting that much work into it.
Old Jun 15, 2011 | 12:03 AM
Fit4Spl's Avatar
The car is way too easy to take apart to not do it the right way, run your power down the driver side of the car door edge, and the speaker/RCAs down the center of the car. Nothing like running them all together and then getting noise in your system, in which you will end up having to redo what you did in the first place. So I would advise saving yourself time in the future and just do it right the first time.
Old Jun 15, 2011 | 12:09 AM
Jamy's Avatar
I wasn't suggesting run them on the same side. I ran my power and signal down the driver side and then my rca's down the passenger side.
Just in case that wasn't understood.
Old Jun 15, 2011 | 02:46 PM
danger69's Avatar
Thanks guys for the input.
Old Jun 15, 2011 | 04:43 PM
Funkster's Avatar
I am with SPL, I have always ran power down the driver's side and RCA/Signal down the center.
Press Fit
Nov 8, 2017 07:10 PM
Michael Raymond
Oct 22, 2016 11:43 PM
GotFitB13
41
Mar 17, 2015 07:30 PM
BraytonAK
Aug 1, 2012 06:44 PM
CuTeBoi
Oct 11, 2008 05:38 PM
