hid install on 2011 fit
Old Jul 9, 2011 | 12:49 PM
fawbusha's Avatar
Can anyone shine some light on how exactly to install? It looks alot more confusing than what I'm used to...
Old Jul 10, 2011 | 12:36 AM
fawbusha's Avatar
Nvm figured it out
Old Jul 10, 2011 | 04:58 PM
FITMugen's Avatar
It depends on what HID kit you get? There are 3 types (I think).
1. Single beam HID - low beam HID only. You lose hi beam.
2. Bi-Xenon HID - Hi/Low HID.
3. Low beam HID / Hi beam regular bulb.
The installation should be PnP.
Old Jul 28, 2011 | 09:28 AM
PEE_ES3's Avatar
Do I have to convert the headlight to projectors? How do I accomplish #3 below.
Old Jul 28, 2011 | 11:40 AM
neil patrick harris's Avatar
you can't. unless you somehow retrofit a separate section of the housing. bi-xenon projectors are the best solution in my opinion. awesome output and it won't cause other drivers to want to crash into your car. and not price-prohibitive (~$300 for a whole kit w/ projectors, ballasts, bulbs and a proper harness).
Old Jul 28, 2011 | 02:42 PM
Java^FiT's Avatar
You can buy a PnP HID kit that is set up this way, it is what I have and I think they are great and it doesnt require you to rip your headlight apart in an oven to install projectors. Personally I'd rather buy aftermarket headlights if I wanted projectors.
Old Jul 28, 2011 | 05:19 PM
PEE_ES3's Avatar
Can you recommend a good aftermarket replacement? Thanks again.
Old Jul 28, 2011 | 06:20 PM
read here. and check out the many threads on morimoto mini projector retrofits here. plenty of us have done it so i hope that gives you confidence that it's not that hard to do. the end result is worth the little bit of extra money and well worth the time to do.
Old Jul 29, 2011 | 09:17 AM
Java^FiT's Avatar
I got mine from here, haven't had any issues at all Top Speed Performance
Old Jul 29, 2011 | 10:13 PM
ediddyfit's Avatar
Just got my HID's installed on my 2011 Fit Sport....I chose the 35watt 5000k kit from
hidkits.com which has a plug and play kit.
Now here is something for all the Fits with DRL, you will have to unplug the DRL fuse which is number 15 I believe and each of the HIGH/LOW on the headlight has a seperate fuse at 7.5Amps...the hid kit recommends that you replace the 7.5 one with a 20amp fuse in which I did for all four. Otherwise if you install the HID's with the DRL in place they will flicker when off since there is not enough power to use the HID's for low on DRL mode.
Just giving everyone a heads up on Fit's with DRL. I got my HID's installed at Power Honda in Costa Mesa and it looks great now....no more crappy oem lighting anymore.
Old Jul 29, 2011 | 10:43 PM
Java^FiT's Avatar
I just want to clarify something because this is not entirely true.
Yes, you do have to pull the DRL fuse if you buy an HID kit that uses just a Lo beam Xenon bulb with no high beam option OR if you are using a Bi-Xenon setup that uses a magnet to move the cutoff shield to produce a lo or high beam setting from one bulb.
HOWEVER...you do NOT need to pull the DRL fuse if you purchase and install an HID kit that is a Hi/Lo setup with a Xenon bulb for the lo-beam and a halogen filiment for the high beam. This high beam bulb is capable of drl usage because it is a standard halogen bulb.
This is the kind I have installed and I still have drl use which is just overall safer to have with the morons on the road. I highly recommend this type of HID kit/bulb setup.
Old Jul 29, 2011 | 11:59 PM
ediddyfit's Avatar
Ummmm I have the BiXenon set up.... so I don't know what you are talking about not having to pull it, but I did get this flickering issue resolved by pulling the fuse.
Anyone else that's doing this with the same set up I have feel free to chime in if you ran into the same issues I did.
But yeah.....As I stated I am very happy with the result.
Old Jul 30, 2011 | 01:06 AM
Java^FiT's Avatar
I said you DO need to pull for bixenon or single xenon, you DONT for a halogen hi/xenon lo combo bulb
Old Jul 30, 2011 | 01:51 AM
ediddyfit's Avatar
Yes you are correct my bad for misreading....
Old Jul 30, 2011 | 06:47 AM
FITMugen's Avatar
I have B-Xenon HID kit and I don't have flickering issue since my HID kit comes with relay/harness. It gets power directly from the battery. Relay just get the signal from OEM harness to trigger ON/OFF.
Old Aug 10, 2011 | 04:54 PM
feichai's Avatar
sorry for bringing this thread back, but do i need to install a relay harness for my hids? i got hids for headlights and fogs, also do i need to swap the fuses for any of the lights prior to turning them on, or am i safe to just install and go. i have a single beam for fogs and hi/lo for headlights.
Old Aug 10, 2011 | 06:03 PM
FITMugen's Avatar
I don't think you need to replace fuse if you install relay for fog lights since the replay circuit get power directly from the battery. The OEM fog light harness just trigger the replay.
If you get a Bi-Xenon HID kit, it should come with a controller/harness. No, you don't need to upgrade fuse. The controller/relay get power directly from the battery. One side of OEM headlight just trigger it. However, DRL light on the dash will turn on. There are some fixes on this issue.
Old Aug 10, 2011 | 08:44 PM
Java^FiT's Avatar
if its a halogen hi/xenon lo then you dont need a harness, or have to do anything with the fuses, the halo hi filament will operate at the appropriate voltage for drl's. You should be good to go, hook em up and enjoy!
Old Aug 10, 2011 | 09:29 PM
feichai's Avatar
sweet! i'm pretty much almost done with the installation. got a weird question though, is the halogen hi supposed to be facing inward of the car or outward?
Old Aug 10, 2011 | 10:12 PM
JJIN's Avatar
sorry to troll a bit but, i cant believe this pnp hid kit trend hasnt passed yet.
fwiw please when you get the chance or the funds, retrofit a set of projectors instead of blinding others on the road. thanks!
