How do I access the washer pump on 09 Fit Sport?
Old Jul 11, 2011 | 01:46 PM
GaryMD's Avatar
Do I need to remove the bumper cover, or just the passenger side wheel and the wheel well liner or ?
Old Jul 11, 2011 | 01:56 PM
Krimson_Cardnal's Avatar
Remove right inner fender. What's the problem, bad motor or no fluid flow?
Old Jul 11, 2011 | 04:22 PM
GaryMD's Avatar
Thanks. Just no fluid flow. No sound from pump either. My '10 Fit had same problem in the winter, but it was under warranty. I assumed an ice block killed the pump. But this one just failed for no apparent reason. I wonder if there's a technical bulletin out on this. Seems like a fairly common problem.
Old Jul 11, 2011 | 05:08 PM
Pump should be easy to get at. Check fuse #21, 15A. Washer motor. Could be a clogged outlet on the motor.
bbb222
Sep 18, 2025 12:07 PM
bbb222
Dec 10, 2018 09:28 AM
BasicWhite
Apr 27, 2015 01:10 PM
EchoDmk
Nov 20, 2014 11:57 AM
tk_jazz
Nov 8, 2008 06:23 AM
