How much
Old Jul 3, 2006 | 01:37 AM
IBTG81's Avatar
How much
Does an oil change cost at the dealership?
I guess I should get Mobil-1, so how much should I expect to pay?
Thanks!
Old Jul 3, 2006 | 05:58 AM
fm2n's Avatar
Thanks!
Walmart has Mobil 1 in a 5 quart jug for $22.xx. I would recommend a Napa Gold oil filter. Honda's filters are now FRAM! Personally when I get my FIT, I plan on using Penzoil Platinum 5-20W with a Napa Gold filter. Some people have said that Mobile 1 runs really rough.
After the change, run it for another 5,000 miles, before the next oil change. Then I would recommend doing changes every 7,500 miles from thereon. If you really care about your engine, there are people out there who do UOA (used oil a.nalysis) to see what elements are shedding from their engine into to oil or if there is any sludging or radiator coolant leaking into the oil (causes sludge).
I'm not sure how many miles you have on your car or how many miles you have before your due change, but I would recommend checking your dipstick to see where your oil level is at, then before the oil change, check again to see how much oil your engine has consumed per so many miles. This is normal until your ring seals break in properly. If you still find that you are consuming oil once those seals have broken in, then there may be something wrong with the rings seals thats not keeping oil out. For newer cars I doubt it will, but it could also be that your engine is running too hot and is boiling over the oil. This usually calls for thicker oil for better heat resistance. In any event, stick with 5-20W until your warranty expires. After that, you can use whatever oil weight that your engine adapts best with.
Check out http://www.bobistheoilguy.com
Andy
Old Jul 3, 2006 | 08:47 AM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
I was told that for the first two oil changes to use real oil because it will help get everything nice and lubed up.. then I can move onto the sythc.
Old Jul 3, 2006 | 08:56 AM
switchbrdopr's Avatar
My first one will be free since they gave me a coupon at the New Car Care Clinic I attended after I bought my Fit. Thanks Koons Honda of Manassas!
Old Jul 3, 2006 | 04:38 PM
chyv1083's Avatar
Andy
That picture isnt right LOL!
clicq
Jun 29, 2011 07:18 AM
mozarwasagenius
Mar 31, 2009 12:54 PM
SmartSizer
Mar 12, 2008 02:15 PM
GSRswapandslow
19
Feb 22, 2008 08:31 PM
ludexr
Sep 17, 2006 10:13 AM
