oil burning
Old Mar 25, 2009 | 11:04 PM
mozarwasagenius's Avatar
oil burning
I admit I wasn't diligent in noting the oil level when the dealer changed it last, but I was surprised when I saw that it was close to low. I added a bit to get it back (about 1/4 quart) to almost full.
Have there been problems with oil burning on these cars? I see no evidence of leaks.
Thanks
Old Mar 25, 2009 | 11:17 PM
shazaam's Avatar
running rp 5-30 I haven't noticed any loss of oil/burning. at 7,xxxmi.
Old Mar 25, 2009 | 11:25 PM
solbrothers's Avatar
havent noticed anything at nearly 18000 miles
Old Mar 26, 2009 | 12:05 AM
artieman's Avatar
no loss of oil here 51,000 miles and counting
Old Mar 26, 2009 | 01:05 AM
stockfitgd3's Avatar
r your sure your using thet right oil filter and good oil, i use 5-20 royal purp and an K&N oil filter, and the car is beautiful, no problems whatsoever
Old Mar 26, 2009 | 02:16 AM
I had the Honda dealership do it. Honda filter and oil. good oil? I couldn't say
Old Mar 26, 2009 | 02:47 AM
well there shouldn't be any oil burning at all. look under the car and see if u can see any oil spots. usually on imports there's a gasket on the drain plugs that have to be replaced every oil change. if u don't replace them they wear out.
Old Mar 26, 2009 | 06:20 AM
Type 100's Avatar
Not really a gasket...they call that a "crush washer"
But yeah, the function is the same.
Old Mar 28, 2009 | 05:54 PM
xtreme's Avatar
I was burning oil and it came down the the valves. The dealership replaced the entire head for me for free and since then i have had no problems.
Old Mar 28, 2009 | 11:37 PM
Thanks for the note. I hope I don't have that issue but I'll definitely keep an eye out for it!
Old Mar 30, 2009 | 12:27 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
My Fit burns oil. You can smell it constantly if the car is running.
I check it often, so far it doesnt seem to be leaving the motor.
Last time I did an oil change it was close to a quart low. So far its staying full.
I havent lost any power and my MPG is still great so I know its not rings.
Plus, if it sits for a while at idle and you tap the gas itll puff blue smoke.
My guess was rings.
Old Mar 30, 2009 | 12:31 PM
sonicsc1's Avatar
i have to add oil at 2500-300 miles about a quart since new now at 36000. dont smell anything see anything ???
Old Mar 30, 2009 | 12:44 PM
Posts in the NUUDE
That seems to be similar to mine. Im at 38k
Old Mar 30, 2009 | 01:55 PM
Sugarphreak's Avatar
Push My Button
Any plans to do a compression test on it Ray?
Old Mar 31, 2009 | 12:54 PM
Posts in the NUUDE
I had thoughts about doing it. Guess it wouldnt hurt?
For some reason I have no drive to work on my Fit, unless its adding accessories.
Hahh
SilverEX15
Oct 26, 2017 07:44 PM
KweenJD
41
May 29, 2014 11:33 PM
Vince_TB
Apr 25, 2014 11:58 AM
GSRswapandslow
19
Feb 22, 2008 08:31 PM
Paulo107
May 31, 2006 09:04 PM
