Question about intake cleaning chemical??
Old Aug 16, 2011 | 07:23 AM
Sherbs_Inc's Avatar
Short Backstory: I got a little busy this weekend and was unable to change my oil so I ran to a "chain" oil place, paid the extra to have the "good" stuff put in according to the owners manual. If any of you ever have your oil changed at these places you know what comes next.
Salesman comes in to make a pitch for the extra maintenance work and what not. I can replace both the cabin and the air filters cheaper than what they can do it for so I spaced off during that part of the presentation. What caught my attention is he started going on about newer cars having Iridium spark plugs and due to the emissions recycling the L15 does it requires a chemical sprayed into the throttle body and run through the fuel system. He said it helps keep the plugs clean and cleans the carbon build up off of the piston tops. He then pointed to my air filter and proceeded to show an elliptical "particulate" catch pattern. Basically the air filter has dark ovals on it instead of a uniform dirty filter. He then said that this chemical, which he never mentioned by name, is hard to get unless your ASE certified and know a distributor to get it.
So my question is this: How much of that is bunk and how much is legit. If this is a real thing whats it called and where can I get it? Its a 2007 with about 55k on it. The intake is getting ready to be replaced so I am curious about this, as this would be the first time I have ever heard of this type of procedure, which he then said he could discount to $130 for a first time customer.
Old Aug 16, 2011 | 12:56 PM
Krimson_Cardnal's Avatar
Run away. NEVER spray anything into the TB to clean it.
Old Aug 17, 2011 | 04:21 PM
Carbuff2's Avatar
I call BUNK!
You can do as well using a Top-Tier gas
Top Tier Gasoline
and occasionally running the car "through the gears". The high RPMs clean out the injectors.
$130? For $50 I'll run it though the gears for ya!
Old Aug 17, 2011 | 04:26 PM
DiamondStarMonsters's Avatar
Originally Posted by Carbuff2
I call BUNK!
Top Tier Gasoline
A good ol' italian tune up!
Old Aug 17, 2011 | 05:46 PM
Old Aug 18, 2011 | 12:07 AM
Sherbs_Inc's Avatar
Awesome, appreciate it guys. I run 'er through the gears every now and again, so basically just some injector cleaner every once in a while and some spirited driving and I should be fine?
Old Aug 18, 2011 | 06:22 PM
Carbuff2's Avatar
Yes....
BTW at 55K miles I would suggest adjusting the valve lash. We did ours at about 60K and it needed it.
clemsonteg
Mar 1, 2013 04:16 PM
T-Fit
Jul 18, 2012 03:24 AM
robothebobo
Sep 12, 2009 08:32 PM
uRabbit
Sep 11, 2009 01:53 PM
xtreme
May 29, 2006 01:36 PM
